Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Closed Thread
Old 01-13-2004, 05:55 PM
customandsound
Guest
Posts: n/a
Default paint removal on alum.
what is a safe paint stripper for alum.... i was blasting it but i noticed i had alot of fine flakes ... do you think that would hurt my part...
Old 01-13-2004, 10:06 PM
skiddz's Avatar
skiddz
I tried this stuff call Stryp-ese. It's a toluolene (or however the hell you spell it) based stripper and it took a LONG time to even bubble the paint on any painted metal. Too much work so now I just chuck it in the blast cabinet and go at it with glass bead. The resulting surface isn't too bad - nothing the greaseless compounds and some elbow grease can't handle. I've had good results blasting at 80psi at around 6-7cfm.
Old 01-14-2004, 12:30 AM
polishinginc
Send a message via AIM to polishinginc
I usually dont bother with stripping paint. Sanding usually takes care of riding your part of paint.
Old 01-14-2004, 06:14 PM
Moderator
bhhodges is on a distinguished road
if you want to use paint stripper use aircraft brand it will eat the paint and you too be very carefull with it.
bill
Old 01-14-2004, 08:38 PM
customandsound
Guest
Posts: n/a
i used that stuff on my car and it took off 4 coats of paint ... i was not sure about using it on alum. i figured it would stain it to the point it would not buff out
Old 01-16-2004, 08:40 PM
mcaswell's Avatar
Caswell Inc Founder
USE VHT STRIP FAST
http://www.caswellplating.com/vht/stripfast.php
Have A Web Site?
Closed Thread
Removing paint from the corners.... cruizer Powder Coating Questions 11 08-15-2005 10:37 AM
clear coating polished alum hybred Metal Polishing Questions 7 08-08-2005 03:58 PM
powder of polished alum? hybred Powder Coating Questions 3 08-07-2005 03:38 PM
transparent paint after polishing Pol3000 Metal Polishing Questions 4 04-23-2005 07:18 PM
Wanting to paint turbo exhaust manifold and downpipe NCspecV81 Powder Coating Questions 1 12-26-2004 07:45 PM
