+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 15
Thread: Clear coating, the epic continues..
  1. Join Date
    Dec 2003
    Location
    So. CA
    Posts
    254
    I polished my 1st piece of steel today, a shift lever from my 4 wheeler. Took forever to sand all the dings and pits out, but polished up like chrome. Once it was done, I hosed it down with brake parts cleaner then let it sit for about an hour before clear coating with VHT.
    Talk about crappy results. The VHT sprayed nice enough, but ended up "migrating" into little bumps as it dried. I was able to strip it all off with laquer thinner and tried again with the same results. I thought it might have been a bit too cool to spray (It was almost 70 here today) so warmed up the can in a bucket of warm water, did the laquer thinner thing, let it dry for 20 mins and tried again. Same friggin' result...
    Does this stuff "smooth" out when you heat cure it? I'd hate to have to bead blast cured clear coat off the part and repolish if it doesn't. I do want to keep the part from rusting and Zoop just isn't in the budget right now. Anyone got any tips on how to get this VHT stuff to gloss over? The couple times I tried it on aluminum it came out pretty nice. WTF is the deal with steel???
    Share with Facebook
  2. customandsound Guest
    i tryed clear coat in a car on a steel part .. it dulled the shine... as soon as i get a chance the fuel rails are off to tom... nissian has been keeping me busy ...
    Share with Facebook
  3. Join Date
    Dec 2002
    Location
    NJ
    Posts
    283
    70 degrees isnt too cool to spray at all, so thats not the problem. However i have no experience with VHT. I can tell you, powder coating a piece of chrome looked extremley nice. I'm sure you saw the picture. You may want to contact a powder coater and have them powder coat it for you with a 200+ gloss poly.
    Share with Facebook
  4. customandsound Guest
    that is right .. i saw the pic .. i was amazed ... of the turn out.. skiddz it looked perfect .. not dull at all ...
    Share with Facebook
  5. customandsound Guest
    i know what you are saying about zoop ... i polished alot of steel parts under my hood and i waxed them with carnuba wax.. the only problem i have is when it is time to clean it it is going to take me a week to get all the polished stuff clean and to shine like the sun.... i did 95% of my motor .. and half of the engine bay is polished and the painted compartment is sprayed with plastic dip .. to cut on noise and it looked good when i dripped it all over .... pic are soon to follow!!!! what out judges i am taking it home !!!!
    Share with Facebook
  6. Join Date
    Dec 2003
    Location
    So. CA
    Posts
    254
    Yeah, I saw the pic. Unfortunately, it would be cost prohibitive to have the 2 or 3 steel parts I'm polishing sent out for clear powdercoat.
    I'm going to have to try again with the VHT or some clear enamel.. I'm going to try a different tack with cleaning the part. I'm thinking the brake parts cleaner or the laquer thinner left something on the part. The VHT can says to use Acetone so I'm going to fully submerge the parts, let 'em sit for 20 mins or so then let 'em air dry all day and try again.
    At this rate, it'll be October before I finish this friggin' 4 wheeler... hehe
    Share with Facebook
  7. customandsound Guest
    i was wondering if clear poly would work better ?if so you can have it sprayed at any body shop for a few bucks ...
    Share with Facebook
  8. Join Date
    Dec 2003
    Location
    So. CA
    Posts
    254
    welp, I repolished the shift lever one more time. Blingitty bling bling!! This thing is (err was) shiny shiny shiny! Did the acetone dip and let it dry for an hour.
    Left the arm and the VHT clear out in the sun for an hour to warm 'em both up a bit. (High 60s today) Sprayed the clear on again. OK, much better. Nice even coat, seems to be glossing well.. Let it dry for 30 mins then into a 250 degree oven for 30 mins. Let it cool to room temp, then in to 350 for another 30. Looking decent, but you can tell the shine isn't like it was, still it's acceptable. Let it cool to room temp then into a 650 degree oven for 30 (just like the VHT label says) mins.
    Timer went off, I shut the oven off, pulled the part out and hung it in the shop to cool. I'm going to have to strip and polish this thing again. The VHT turned into a translucent black/grey film, kinda like black-chrome.
    As soon as the part cools enough to touch, I'll take some pics and post 'em here:
    http://users.adelphia.net/~skiddz/
    Share with Facebook
  9. Join Date
    Dec 2003
    Location
    So. CA
    Posts
    254
    Pics are finally up. Ran outta storage space and had to resize all the pics to clear up some room. Looks like I'm going to have to buy more space or try to host some of this stuff from home.
    Share with Facebook
  10. Join Date
    Dec 2002
    Location
    NJ
    Posts
    283
    Wow, that dodnt turn out good. I suggest getting it powder coated. You seem to be putting a lot of time, which equated to money....powder coating isnt that exspensive, but thats my 2 cents . Good luck and like always post your results!
    Tom
    Share with Facebook
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Thread Information
Users Browsing this Thread
  1. clear coating polished alum
    By hybred in forum Metal Polishing Questions
    Last Post: 08-08-2005, 02:58 PM
  2. Powder Coating Clear over Copper Plating
    By wc1971 in forum Powder Coating Questions
    Last Post: 07-27-2004, 09:15 PM
  3. Powder Coating Clear Over Chrome Plating
    By dsalter in forum Powder Coating Questions
    Last Post: 02-17-2004, 03:46 PM
  4. Clear coating?????
    By Dermagrfx in forum Powder Coating Questions
    Last Post: 08-23-2003, 11:31 PM
  5. Clear coating?
    By Derrick in forum Metal Polishing Questions
    Last Post: 06-16-2002, 10:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
