Old 01-30-2004, 09:46 AM
joenintiesc
Default protecting polished aluminum?
Newbie here! I've read the free manual and many posts in this forum. Before I begin getting into the whole process of polishing/buffing, which I'm eager to start, I was wondering what is the best method for protecting the finished piece. Specifically car underhood/engine items.
I've read mixed things about diy clearcoating with a spray can (dulled finish, yellowing over time...)
I know there is a wax that Caswell sells, but is that meant for hi-temp applications? Would it last under those conditions, or just melt off?
I'd like to find something I can do myself, as opposed to paying for clear powder coating, if possible...
Thanks, and it's great this forum exisits!
Old 01-30-2004, 06:20 PM
customandsound
Guest
Posts: n/a
zoop ... caswell sells it ..
Old 01-30-2004, 07:28 PM
joenintiesc
Thanks! I've read about Zoop and it sounds great. Little pricey, though...
Any other methods, or tried and true hi-temp clear coats, that might be a cheaper yet effective alternative? The protective wax is no good for the engine compartment I would imagine...
Old 01-30-2004, 08:07 PM
customandsound
Guest
Posts: n/a
you can use it under the hood ... i use carnuba wax .. and for clear coating ... it dulls the shine .. you don't want to do that ... i just sent tomg552001 a set of polished fuel rails to clear coat for a challenge.. take a look at them i keep you posted ... then you can see the clear coated look
Old 01-30-2004, 08:21 PM
joenintiesc
Thanks! I'd like to check out a pic of your rails when they're done.
I was at the NY Bike Show last month and bought a two-stage metal polish and sealer kit. During the demonstration they were using it on soda cans, and after the sealer was applied water would just bead and roll right off the surface. Yes, I'm sure I overpaid for this stuff and it's probably no different than most formulas out there... But at the time it looked like just what I was looking for to put the finishing touches on an intercooler pipe I was trying to polish the letters on. Anyway, I used it on a polished i/c I bought and it really brought out a nice shine just using a hand cloth. I wonder how well/long it would hold up under the hood?
So I guess the best choices are powdercoating if it works out to be less expensive than Zoop, or the wax for a temporary protective measure. Clearcoat spray sounds like too much trial and error to find the brand that will work the best.
Thanks!
Old 01-31-2004, 08:11 PM
customandsound
Guest
Posts: n/a
can you email me i got a pic of a clear coat on polished ... it is a harley trannsmission cover ,,,, customandsound@yahoo.com
Old 02-01-2004, 03:05 AM
tomg552001
Send a message via AIM to tomg552001
Heres a picture of a test piece i did. I clear coated chrome...as you can see it looks like unclear coated chrome. Once customandsounds fuel rails get here i will be caoting them, and posting some before and after pics.
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Need help polishing my polished aluminum wheels suparida Metal Polishing Questions 12 09-02-2005 09:08 AM
How do you clean your polished aluminum? mach1man Metal Polishing Questions 3 10-02-2004 02:42 PM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 01:19 PM
VHT-Clear or Glisten PC for polished aluminum protection? Great_Scott Metal Polishing Questions 5 04-08-2002 08:15 PM
Powered by vBulletin® Version 3.7.0
