When polishing aluminum is it possible to get a mirror shine finish? or when you look at the piece your doing up close, is their always going to be impefections, like hairline scratches.
I've been working on some atv rims and they look great from a foot away but if I get close to them I see alot of imperfections. Is their anything I can do to make them perfect, or should I just be happy with what my results are now? BTW i've been sanding them first, then using a sisal wheel with black, then spiral with brown, then loose with white. (With white what works better the liquid or the bar compound?). I use a 3/4 horse grinder that has 3 amps for the large areas and a die grinder for the real tight areas. Any suggestions would be great |
I first use greaseless compounds 80,120,180,240, then I wet sand with 400 and finally 600. It comes out nice and smooth but my problem is when I'm done polishing. Its nice and shiny but their are hairline scratches. can you think of anything im doing wrong in my polishing process.
Like u said Bhodges, last night i tried something different. I had a feeling maybe I wasn't cutting deep enough into the metal so I decided after a good pass with a sisal and black I switched to a spiral and black. The almost perfect shine came through no scratches pits or anything. After both of those passes I hit it with white and now you can read the newspaper by it. Amazing results by just changing the wheel i was using.
I will post pictures as soon as I get ahold of a camera. I'll post before and after pics because anybody that knows the 97 banshee knows how godawful the gold rims are. |
I know exactly what you're talking about mole. Add 10 years to the age of your Banshee and you've got mine. I'm a little over halfway done with the rebuild and there's not a single aluminum part on it that hasn't gone under the buffer. Still struggling with the carb bodies, but those are like trying to polish the nooks and crannies of an english muffin...
All in all, it's been a great learning experience. I think I've got a handle on what I need to do to get excellent results now as my last 4 pieces have come out extremely nice. Check out the pic I just posted in the "got a new toy" thread. How'd you get the gold anodizing off the rims? Chemically or with sanding/buffing compounds??? I've got a set of rears I'd like to revamp... |
The first thing I did was take the tires off (im getting new ones) and the valvestem makes things alot easier. Next I took my heat gun to the rims and made them just hot enough that I could feel the heat through my gloves. (I read a bunch of different sites before I did this and most of them said it works best when the metal is hot). Anyways then I just sprayed on the oven cleaner. Spray it on thick and let it sit for a few minutes and then see if anything is happening, when you see it starting to come off spray more on and as it thickens it will start falling off. Have a good area for this cause its messy. Then if all of it doesn't come off by the spray then take a sponge and start wipping it down. BTW only 2 of the 4 rims came completly clean of the anodizing. But don't worry only a little bit is left on the rim.
What I did after all that was took some greaseless compounds to it from 80 grit through 240 and the rims were compeletly clean and ready for a little bit more sanding. After the greaseless I sanded very little with 400 wet then 600 wet. It left the rims almost polished. Then u just polish them. Its a slow process but mine don't need to be ready till the end of march when I goto Pismo. The only problem im having is with the center of the rims they r a pain in the rear to get to. I even have a flex shaft but cant seem to find the perfect bob to use, that and the centers seem to be really pitted compared to the rest of the rim. If you have any advice on what u would do for the centers let me know. |
| good result but not tey perfect. | sin | Metal Polishing Questions | 2 | 02-20-2005 09:03 PM |
| here is the perfect hobby setup ... !!! | customandsound | Powder Coating Questions | 7 | 11-27-2004 11:20 PM |
| More perfect shine | Chopper Doc | Metal Polishing Questions | 4 | 03-03-2002 12:37 PM |
| getting a perfect finish | mtlplshr | Metal Polishing Questions | 2 | 02-06-2002 10:41 AM |
| perfect shine | mtlplshr | Metal Polishing Questions | 1 | 02-03-2002 11:20 AM |
