OK I understand what you are saying about speed. I do have a 15 amp buffer at 3500 RPM. An 8" wheel will have a third higher surface speed than an 6" so why would you want to use a smaller wheel. The only reason would be if you don't have enough power to maintain the surface speed of the wheel. Since the loose is soft I would think that you could stop most buffers regardless of whether it was 8" or 6", so the issue becomes how much pressure will it take before slowing up. If you can't maintain the correct pressure and surface speed combination then you won't get the desired results. The problem with this is that I have no experience to know what is fast enough with adequate pressure. I don't know if the problem is with the maintained speed or something else. Experimenting adds more variables and confusion unless you end up solving the problem. Which at this time alludes me. I understand that heat is our friend but how warm should the piece get with the loose and white. Maybe I'm not generating enough pressure to get it hot enough. But then again it could my sisal with black polishing.....
3/4 HP, 115V.... with the loose wheel I can slow it down pretty easy which makes me think it might be a heat issue. It is hard to slow down my sisal and somewhere in between for my spiral. I can get the sisal hot enough to where it is uncomfortable to hold the metal, the spiral gets pretty warm border line hot and the loose only gets real warm. Maybe pressure / heat is the issue. Originally I had experimented with a spiral and brown on a 4" wheel on a 12,000 rpm hand grinder. I would say I had plenty of heat and maybe I didn't have the haze problem...
You want to apply as much pressure as possible without significantly slowing your machine down. When i polish, the part is always mighty hot...sometimes even hard to hold even when using the loose wheels. I honestly think smaller wheels will do you better along with applying more pressure. I have no idea about the technical surface speed all i know is what works for me. When i use 8 inch loose wheels the machine bogs easiar and i get a haze like you mention. I suggest picking up 2 loose 6 inch wheels and giving it a shot. It's $10 worth being spent to possibly solve a problem. Trial and error will yield you your best results. Eventually you'll learn the right pressure, the right speed to move the part along the wheel, the right cutting actions to use at the right time, and the right amount of compound to load on the wheel. Things like this dont come over night. I've been polishing for over a year and a half, and i still have room for improvement. The best thing you can do, is experiment and see what combinations work best for you.
I need to order some other stuff so I will probably try that. I am also running two 1" wheels so I'll try 1, I also have a 4" so I might experiment with it on a grinder....
I'll let you know how it turns out.... maybe I'm actually getting closer to solving my problem and learning how to polish..... |
| Removing small scratches from Chrome | mlust | Metal Polishing Questions | 5 | 07-30-2008 02:39 PM |
| Final Scratches from buffing wheel | regulator | Metal Polishing Questions | 2 | 01-06-2005 11:03 PM |
| SCRATCHES | clockman | Metal Polishing Questions | 5 | 06-08-2004 08:18 PM |
| Stainless steel Scratches | SP4SPD | Metal Polishing Questions | 7 | 01-12-2004 08:42 PM |
| How Do I remove tiny, light scratches from Aluminum? | chem_man3 | Metal Polishing Questions | 17 | 03-04-2003 11:46 AM |
