Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Closed Thread
Old 02-10-2004, 03:43 PM
Caswell Platinum Member
dstiver
Default Titanium Polishing Advice
I've got a question about polishing Titanium.
I'm making several fairly large (4"-6"x8"-12") pieces with 6AL-4V titanium sheet. Sheet is coming to me in a normal mill finish, and after forming, I need to bring it to a full mirror polish.
I've tried the 3M surface conditioning disks in an angle grinder like I would typically use as an initial step on mild steel or 304 stainless. . . and they don't seem to do much of anything.
Finally ended up doing initial sanding with Silicon Carbide wet/dry sandpaper (working 220-400-600-800-1000) and then on to the buffer (2 HP, 10" sisal wheel -w- emery, followed by 10" spiral -w- stainless compound, followed by 10" loose -w- white compound). . .but long and short. . . I just can't seem to get that "shave in it" mirror polish.
thoughts? Advice?
Old 02-10-2004, 05:15 PM
mcaswell's Avatar
Caswell Inc Founder
After 1000 grit, I wouldn't be using a sisal wheel. Use the Spiral sewn, or skip black compound all together. Finish with Canton FLannel and a Blue compound
Have A Web Site?
Closed Thread
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 62 05-18-2009 02:23 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
How to polish titanium? drajala Metal Polishing Questions 1 05-11-2005 12:44 AM
Titanium Anodizing ron423 Anodizing Questions 4 08-23-2004 05:09 PM
Intake Manifold Polishing Dino6961 Metal Polishing Questions 2 09-05-2002 01:47 AM
