I am polishing a friends 2002 GSXR 750 frame andd I was wondering if any one has ever removed the bikes vin # sticker that sits in the middle of the frame in plain sight. Is it legal, or more importantly Possible. Also, I am polishing with a 7" grinder and was wondering if I have to do the cut/color in seperate steps or do all cut first then color. Just wondering because its easier just to move back and forth.
you can not remove the vin# ... that is not legal ... you may want to check with your local state police ... by removing it . will make it look funny when or if you get pulled over .. they will try you up for a while to figure if it is stolen .... cut a few strips of duct tape and cover it ...... you do your cut ... then the color .. i do it with each compound i use .. but the white i use it for color....
Actually, I did that to my 96 gixxer 750, I removed the black tag on the left frame spar. Actually the vin #'s are punched through that tag and into the frame itself. If you remove the tag, the #'s are still imprinted under the tag and in the frame. I did it, never had any problems, and the vin the use mostly anyways is the one on the steering head. If the #'s match on the head and the spar, you will be fine, which they should no matter what. Makes for a cleaner lines, but if you doubt it, tape it and do around it.
i talked to my uncle about this .. he is a cop .. he said if there are some kinds of numbers on the frame . the ones that were stamped form the maker or the ones you stamp in is all legal as long as they match the title and the dmv.... then i was also told that 5 out of 10 cops don't even check the numbers ...
| PC'ing an old truck frame... | dansilbaugh | Powder Coating Questions | 5 | 07-22-2005 04:11 PM |
| Frame polishing....same process...2 different finishes? HELP | bairdmotorcycles | Metal Polishing Questions | 15 | 06-27-2005 03:13 PM |
| polishing frame | shaybirde | Metal Polishing Questions | 4 | 04-23-2005 11:18 PM |
| Frame Polishing Question | SICKGIXX | Metal Polishing Questions | 10 | 03-18-2003 10:50 AM |
| Frame frustrations | Josh | Metal Polishing Questions | 22 | 02-20-2003 11:15 PM |
