  #11 (permalink)
Old 03-04-2004, 02:34 AM
skiddz's Avatar
skiddz
It doesn't mar the finish? I've seen that stuff spot aluminum in a heartbeat at 10:1 mixes.. Maybe I'll try that on a scrap piece... There's got to be a cheaper cleanup method...
Still wanna build an ultrasound unit tho. heheh
  #12 (permalink)
Old 03-05-2004, 10:51 PM
customandsound
Guest
Posts: n/a
opps that is the wrong mix ... i mix 1 gallon to 5 gallons of water ..depending on what i am cleaning ... for the hot tank i use 3gallons to 2 gallons of water ...
  #13 (permalink)
Old 03-08-2004, 02:09 AM
skiddz's Avatar
skiddz
I tried Castrol Super Clean in a 25:1 ratio. Didn't do much at all.. 10:1 seemed to work ok tho. Still required a sponge to attack some of the weld beads and down in the corners but seemed to do a decent job.. I'm a bit leary of trying any stronger ratios tho. I've seen this stuff discolor aluminum in just a couple seconds of exposure.
How long do I work the Black/Brown Compounds for? picasso1850 Metal Polishing Questions 6 04-01-2005 06:13 PM
self cleaning ovens Blademan Powder Coating Questions 3 08-06-2004 11:16 AM
polishing wheels and compounds gottago_joe Metal Polishing Questions 2 06-13-2003 03:30 PM
Compounds jhearn Metal Polishing Questions 1 05-14-2003 11:05 AM
Greaseless Compounds zx7rwinered Metal Polishing Questions 1 10-05-2002 01:06 PM
