Maybe I shouldn't use the word "scratches", may be misleading.
Steps were: Sand down to 2,000 Sisal & Black Spiral & White Loose & White What ever I'm seeing is so faint that it looks like it is caused by ANY micro abrasive material that may be in the Loose & White. They are as fine as if you were to wipe the dust off of the surface, without using a damp cloth. Maybe it's just marks from the loose & white wheel? They always show up in the last direction I was buffing. It looks as shiny as a mirror, until you tilt it a little and the lighting changes, then it looks a little foggy. I know I sound nuts, but it's like getting too close to perfect and not being to get quite there. |
I did find that when you first put two wheels together, Sisal or what ever, you have to rake them to get the two surfaces even. For some reason they are not exactly a perfect match and one wheel can be higher than the other.
| input on aluminum polishing and need help choosing a buffer | Sid03 | Metal Polishing Questions | 7 | 08-09-2004 11:21 AM |
| what speed buffer | low900rr | Metal Polishing Questions | 4 | 02-26-2004 01:59 AM |
| Straight shank hand held buffer | buzzurd | Metal Polishing Questions | 4 | 01-19-2004 09:56 PM |
| 2 hp buffer | bhhodges | Metal Polishing Questions | 2 | 11-30-2003 08:47 PM |
| hand held drill...or 1/2 hp buffer? | shine | Metal Polishing Questions | 6 | 08-20-2003 05:42 AM |
