Old 02-18-2004, 12:03 AM
bigfishon1
Default Emery vs Greasless
Greetings,
New around here but not new to polishing. I have been polishing aluminum wheels for some time now using a pneumatic die grinder and recently started using an electric angle grinder with plenty of speed and power.
I typically start with the greaseless compounds 80, 120, 220 then into tripoli then white rouge. I figured I would try something different and start with the emery compound and see how that worked. It seems to be too fine to cut into the wheels. I am using it with a 6" spiral trated buff.
From what I have read it should be used first for almost all jobs.
My objective is to remove the anodization that some of the wheels have without "scratching" like the greaseless creates. When I use a 120 grit it is too course. When using a 220 grit too fine. Figured the emery would be in between.
Any help would be greatly appreciated.
Thanks!
bigfishon1
BTW, great products and great info forum!! Thanks
Old 02-18-2004, 01:55 AM
skiddz's Avatar
skiddz
Caswell sells a chemical stripper for removing anodizing. I've had good luck with oven cleaner in removing anodizing.
Emery *might* remove anodizing when used on a sisal wheel. I know it'll strip paint and powdercoating - albeit slowly.
Mole here on the forums stripped anodizing from some ATV wheels recently and the polished results look good. I'm going to be doing the same in another week or so and will go the oven cleaner route before a wheel hits aluminum.
The 1st round on the buffer will be a couple 6" sisal wheels loaded up with emery followed by tight spirals and tripoli, then loose wheels and rouge.. I seem to get pretty good results with this method..
Good luck!
Old 02-18-2004, 08:01 AM
customandsound
Guest
Posts: n/a
when using greaseless from what i learned .. you don't go in to the emery til you are done with the cutting .. the emery dose take the cutting down to a workable surface ... but it kind of defeats the greaseless ... i did a intake with just emery and it took it down dut after the greaseless and some wetsanding to even it out it looks great ..........
as for stripper ... easy off oven cleaner works just as good
Old 02-18-2004, 08:54 AM
bigfishon1
Thanks for the feedback! I have heard of the oven cleaner but also heard mixed results. It won't hurt to try. If not I will go with Caswell's stripper. Although if the same as aviation stripper then the wheel will just laugh at it.
Hmmmm...I tried emery on sisal and it also didn't do much.
These wheels are Porsche wheels which are about 30 years old. Not sure if the final finish has been clear coated or clear powder coated. I just know 220 struggles with it and 220 takes a while. And emery doesn't do much.
I will try the suggestions and post.
Thanks!
Old 02-18-2004, 06:59 PM
customandsound
Guest
Posts: n/a
emery dose 75% of the polishing .. it is the longest part other than sanding ... you may want to try aircraft stripper to you can get it at almost any auto part stores for under $11 bucks i use a lot of that to ...
Old 02-18-2004, 09:55 PM
bigfishon1
Aircraft stripper will just sit there while the wheel laughs at it
Will be starting with the emery soon.
Here is a link with some pics of some of my refinishing work on Porsche wheels if anyone is interested:
http://community.webshots.com/user/bigfishon1
Look under "Some Examples of My Refinishing Work"
Thanks again!
  #8 (permalink)
Old 02-19-2004, 06:45 AM
mcaswell's Avatar
Caswell Inc Founder
Aircraft Stripper is Methlyene Chloride, a strong solvent that breaks down paints and lacquers.
Anodize layer is NOT a paint or lacquer
The main ingredient in Anodize Stripper is Sodium Hydroxide, which attacks and dissolves aluminum.
Have A Web Site?
  #9 (permalink)
Old 02-19-2004, 08:49 AM
customandsound
Guest
Posts: n/a
skiddz & bigfish can you email me .. i got some info for you ...
  #10 (permalink)
Old 02-19-2004, 12:16 PM
skiddz's Avatar
skiddz
Same active ingredient as my oven cleaner. :)
After 1500g sanding, and black emery, frame has black streak fizlfry Metal Polishing Questions 8 04-26-2005 10:09 AM
greasless compounds BUFFMAN Metal Polishing Questions 2 02-05-2004 12:28 AM
greasless compound spydersac Metal Polishing Questions 1 08-15-2003 01:13 PM
Problems with emery compound hue Metal Polishing Questions 13 03-03-2003 09:31 AM
