Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
  #31 (permalink)
Old 11-18-2004, 12:23 PM
amtrakr41
Default Oven Cleaner Overspray
O.k, so I finally got motivated to polish my bike frame. But was lazy in the fact of masking areas that the cleaner should not have been able to get on. I now have areas on the frame that are not protected with anodize due to the cleaner and I can't get to in order to polish.... Any one have input on what to do on my course of action, because those areas are just plain ugly as hell now too........I'm thinking wire wheel on a DREMEL tool, bad or good idea? Anyone?
  #32 (permalink)
Old 05-07-2006, 05:52 AM
chromepl8tr
Default Re: MOTORCYCLE POLISHING 101 CLASS IS IN SESSION!
Ha Ha very good. The only thing I would do different is use a 6" tightly stitched yellow treated buff with tripoli in place of the sisal with emory. But your system works well for you and that is all that counts. Although I think tequila and vicodin works much better for the final process.
  #33 (permalink)
Old 07-13-2007, 10:05 AM
cbrooks's Avatar
Caswell Inc Staff
cbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of light
I would recommend using the glare professional polish to seal in the finish. It is a two step process; the first coat is rubbed in until it disappears then the second coating is applied and allowed to dry to a haze then buffed out. It will provide up to 5 years of protection. It will not discolor from the heat generated by the motor.
Craige Brooks
Have A Web Site?
  #34 (permalink)
Old 10-05-2007, 04:07 PM
shocktek is on a distinguished road
this is an excellent how to and keep referring back to it like every ten stinking minutes. Do you recommend the blue compound at all or just stop with the white.
  #35 (permalink)
Old 10-05-2007, 06:43 PM
I only use blue for plastic. Usually stop with white for aluminum, green for stainless. Red after white will give it a blinding shine and it's good for fine metals like gold, silver, etc.
  #36 (permalink)
Old 01-27-2008, 09:51 AM
boxertricks is on a distinguished road
Thumbs up Re: MOTORCYCLE POLISHING 101 CLASS IS IN SESSION!
Hi guys that is really helpful because i am a complete novice would you mind answering a few questions for me bro, iv got a kit but it only contains 3 compounds will i get the same finish as you even though you used 4? i heard that rouge compound is for gold? anyway i also got 3 bags of grit abrasives do i need to use these? because im going to sand and wet flat? and finally will the 3 bars of compounds complete polishing 4 17" alloy wheels? thanks again your post was cool to read. Dave
  #37 (permalink)
Old 01-28-2008, 11:02 AM
boxertricks,
Yes the three compounds that you want to use are Emory, Tripoli and White.
What "rouge" compound are you talking about?
Are you talking about media blasting grit or greaseless?
Three bars will be sufficient to do four 17" wheels. What condition are your wheels in now? Do they have any coating on them? If they don't have any scratches in then that your fingernail will catch on then you can just start polishing them. Start with Emory on a sewn buff.
John
  #38 (permalink)
Old 01-28-2008, 05:12 PM
cheers john
My kit has the equivalent to emery, tripoli and white (grey, green and blue) but im going to get some white anyway because iv heard its better for finishing.
there just called grit abrasive compounds-but i dont think i need to use these if im going to sand and wet flat from 100-1200 do i>?
im talking about red rouge should i use this compound somewhere in my polishing process?
even though im a begginer as long as i take my time and go it properly do you reckon ill get a mirror finish on the wheels?
no there quite rough theyv got paint on and some kurbing marks whats the best way to get rid off these before polishing?----sand them out?
thanks alot
dave
  #39 (permalink)
Old 01-28-2008, 05:15 PM
o yeah obviously im going to paint strip the wheels first and degrease them, cheers
  #40 (permalink)
Old 01-29-2008, 11:24 AM
boxertricks,
Strip the wheel and see what you have. The Emory polishing compound is about 400 grit so I wouldn't sand any further than that. The curb rash will have to be sanded out. If you have a fairly smooth surface after you strip, just start with the Emory on a sewn wheel and see what you get!
Just stick with the three compounds Emory, Tripoli, and White.
John
Polishing a motorcycle engine mpgcustoms Metal Polishing Questions 2 06-11-2005 01:58 AM
motorcycle polishing questions shaybirde Metal Polishing Questions 3 04-30-2005 02:56 PM
NAUTICAL METAL AND MOTORCYCLE POLISHING IN FLORIDA! NautiShine Services Offered/Wanted 5 06-08-2004 08:21 AM
Motorcycle Engine polishing tomlando Metal Polishing Questions 6 01-17-2004 04:28 PM
Polishing aluminum motorcycle wheels emprcyrul Metal Polishing Questions 7 02-15-2003 11:28 AM
