+ Reply to Thread
Page 7 of 7
FirstFirst ... 5 6 7
Results 61 to 63 of 63
Thread: MOTORCYCLE POLISHING 101 CLASS IS IN SESSION!
  1. #61
    Join Date
    Jul 2005
    Posts
    495
    Default Re: MOTORCYCLE POLISHING 101 CLASS IS IN SESSION!
    Quote Originally Posted by boxertricks View Post
    Iv just looked at the edge of my rims aand theres some small chunks missing through damage is there any way i can repair this? thanks
    If you're going to polish them then about the only way to fix the 'chunks' is to TIG weld them. Then again you have got to figure the cost of the repairs versus the cost of another set of wheels!
    then im going to go to 80-120-300-400-620-800-920-1000-then im going to start polishing
    Your wasting your time and money using all those different grits of paper. Match the finish to the surface to be polished to the grit of the sand paper. The Emory rouge is about 400 grit so you won't need to use any finer grit paper that 400 grit!
    Try using a flap wheel on your spokes to smooth them out. There fairly pliable and should contour to the spoke.
    John
    Share with Facebook
  2. #62
    All of the pictures for this guide seem to be corrupt Anyone else having this problem??
    Share with Facebook
  3. #63
    There are pictures?
    Share with Facebook
+ Reply to Thread
Page 7 of 7
Thread Information
Users Browsing this Thread
  1. Polishing a motorcycle engine
    By mpgcustoms in forum Metal Polishing Questions
    Last Post: 06-11-2005, 12:58 AM
  2. motorcycle polishing questions
    By shaybirde in forum Metal Polishing Questions
    Last Post: 04-30-2005, 01:56 PM
  3. NAUTICAL METAL AND MOTORCYCLE POLISHING IN FLORIDA!
    By NautiShine in forum Services Offered/Wanted
    Last Post: 06-08-2004, 07:21 AM
  4. Motorcycle Engine polishing
    By tomlando in forum Metal Polishing Questions
    Last Post: 01-17-2004, 03:28 PM
  5. Polishing aluminum motorcycle wheels
    By emprcyrul in forum Metal Polishing Questions
    Last Post: 02-15-2003, 10:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
