Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Closed Thread
Old 02-25-2004, 01:43 PM
BUFFMAN
Default abrasive wheel system
Has anyone used the abrasive wheel system? I'am looking for somthing that last longer than greasless compounds. It seems to take a long time to sand aluminum valve cover,with 80 grit greasless. any suggestions?
Old 02-25-2004, 05:30 PM
low900rr
Ive been wondering the same thing. help us out someone. thanks
Old 02-25-2004, 06:27 PM
JHFGSX9D
i have had good results with the abrassive wheel system if we are refering to the glue and sand method !! it really dont last any longer then the greasless but it is far more aggressive then greasless it really cuts sanding time down drastically!! i do reccommend this system to anyone !! i use the glue and sand method to cut the casting out then go over it with an 80 grit greasless to get all the scratches out the abbrassive wheel system cuts pretty deep so you need to remove the scratches !! im really bad at explaining stuff like this so if im not very clear ask and i will do my best to explain!!
Closed Thread
Wheel out of balance Trixxr Metal Polishing Questions 6 06-15-2005 05:27 AM
Abrasive wheel system, or Expanding wheel? easleysp Metal Polishing Questions 4 05-11-2005 01:41 PM
Sisal wheel question gmascolo51 Metal Polishing Questions 3 04-04-2005 12:06 PM
Final Scratches from buffing wheel regulator Metal Polishing Questions 2 01-07-2005 12:03 AM
motorcycle wheel polishing...the whole wheel maddness Metal Polishing Questions 2 01-13-2003 12:37 PM
