Old 03-04-2004, 10:08 AM
Default scrubber,abrasive or setup
What is everyones experiences with scrubber wheels, nylon abrasive wheels and set-up wheels(abrasive wheel system). What are the pros and cons of each? I want to prepare carbon steel, aluminum, ect prior to triple plating.
Old 03-05-2004, 04:58 PM
Shevalik
I have just recently started using 2" nylon discs for surface prep before plating. I have used medium and fine discs. I think they work really well because they are more gentle on the base metal than sanding discs. I have a tendancy to make more gouges than remove them when using sanding discs. The nylon are good for getting casting lines, pits and gouges out quickly.
Shevalik
Old 03-05-2004, 09:58 PM
customandsound
Guest
Posts: n/a
they sure beat sanding by hand ... and when you are done you look like pig pen with the dust ..... they cut you prep time down alot ..
Anyone setup for production Copy Chrome giles0 Services Offered/Wanted 2 08-19-2005 10:25 AM
My setup pdeinc Powder Coating Questions 7 06-28-2005 03:09 PM
New small shop setup kickn Anodizing Questions 32 06-08-2005 06:42 AM
here is the perfect hobby setup ... !!! customandsound Powder Coating Questions 7 11-27-2004 11:20 PM
pc efi setup 99blackbird Powder Coating Questions 2 12-03-2003 02:41 PM
