http://cgi.ebay.com/ws/eBayISAPI.dll...70974&rd=1
14.2 amps!!!!! i nwko that thing can easily pull a 19 inch wheel. right? |
but i didnt' mention that my buffer is only 2.1 amps. thats very little, i thikn i need a stronger one. w/ that 6 inch wheel, mine bogs down. so i dont know what to do. is that why my parts are not shining up so nicely? it's hard to make ti like perfect.
if someone could give me a list of everythign i should get, i was thinking: buffer - 6-8 amp spiril wheel (w/ black compond) cotton sewn(w/ brown compound) what i currently have loose cotton (w/ white compound) white compound brown compound black compound will this produce the results i'm lookign for? |
this was done with a little craftsman grinder it is ok looking .... and the list you got is good for starters .... after you get good you will want to try other things .... i don't use sisal anymore...... it is sprial for most of the work....... if you sand the part good and smooth a sprial with black will bring you a nice shine and then to white on a sprial .... skipping out the brown.... you will learn alot of tricks
that little bench grinder 2.1 amps bogs down a lot. and it keeps giving me that hazy spiderweb scratchy thing, i can't get rid of it. i'm using cotton wheel on all three compounds. i might need to use greaseless compound?
why can't i make it perfect? what is your setup? i want to be able to perfect this. but i think i dont have teh right tools for the job. |
Shoot me an E-mail @ arcv2003@yahoo.com, I'll show you some pics of my 11 amp, $25 angle grinder setup. So far it's working great with the Caswell buffing wheel/compound kit.
| input on aluminum polishing and need help choosing a buffer | Sid03 | Metal Polishing Questions | 7 | 08-09-2004 10:21 AM |
| New 8" Buffer...Now what? | tribalimage | Metal Polishing Questions | 17 | 03-13-2004 06:42 AM |
| what speed buffer | low900rr | Metal Polishing Questions | 4 | 02-26-2004 12:59 AM |
| Straight shank hand held buffer | buzzurd | Metal Polishing Questions | 4 | 01-19-2004 08:56 PM |
| 2 hp buffer | bhhodges | Metal Polishing Questions | 2 | 11-30-2003 07:47 PM |
