Old 04-10-2004, 08:05 AM
Rickc
Default Shaft Extenders
I am going to order a shaft extender for a motor to use as a buffer. The shaft is 5/8" and rotation is CCW. Does the rotation direction determine whether I need a right hand or left hand thread? If so, which would I need for CCW rotation?
Thanks,
Rick
Rickc
Old 04-10-2004, 10:37 AM
customandsound
Guest
Posts: n/a
yes it dose... you don't want the buff to come loose when you are working on a part ...... caswell got them in both left and right hand thread ...
i got them on a motor and the ext. shafts are nice .... you can get the part around more
PROD SAXLLT5 Extra Long Shaft Adapter 5/8" Bore Left Thread $10.75
PROD SAXLRT5 Extra Long Shaft Adapter 5/8" Bore Right Thread $10.75
http://www.caswellplating.com/buffs/longsa.htm
Old 04-10-2004, 05:39 PM
Rickc
Default Shaft extenders
So, is it right-hand thread for CCW rotation or vice versa? This sounds correct to me.
Rick
Rickc
Old 04-10-2004, 06:05 PM
customandsound
Guest
Posts: n/a
yes .... if you got a double shaft get both .... i got the std and the ext. ones
Old 04-10-2004, 09:31 PM
Rickc
Thanks,
I'm ordering tonight!!
Rickc
Old 04-10-2004, 09:40 PM
customandsound
Guest
Posts: n/a
any time
Buffing speeds & flex shaft? Tallman Metal Polishing Questions 2 06-13-2004 12:19 PM
Fine polishing with the Flexible shaft grinder c_gismo Metal Polishing Questions 3 11-27-2003 12:14 PM
What kind of shaft extension do I need???? polishinginc Metal Polishing Questions 1 06-29-2003 10:44 AM
flexable shaft polishing sparts Metal Polishing Questions 1 05-09-2003 10:01 AM
flexible shaft polisher/sander ezmoney23 Metal Polishing Questions 1 03-16-2003 06:26 PM
