I am very new to the polishing arena. I've searched the forums pretty extensively and am unable to come up with a definitive answer (instruction) to my delema. I own a '99 Dodge Durango show vehicle and I am in desparate need of polishing to a mirror finish several pieces of the engine compartment. These pieces are: The alternator/ac condenser bracket The AC Condenser housing and the... Alternator housing. I'd be lying if I told you what type of metal these pieces are made off because I don't know. They are just the typical cast material that you find in most vehicles. I'm sure some of you are familiar with. What I do know is that I have seen these exact pieces polished to a mirror finish... so I know that it can be done. Hundreds of dollars are needed to have this done by someone. I don't have the money. I would be truely indebted to anyone that could please explain to me what is needed and to process involved (in detail) to get these pieces polished to a mirror finish. You can take a look at my engine compartment at http://members.cardomain.com/tcalyen on page 4 at the bottom. Please let me know ASAP... I have several shows in the comming weeks and I'd like to get this done pronto. I just have no idea on how to do it. Thanks, TCalYen |
First, let me say Nice truck.
Thanks for the reply...
I'd still like to know how to do it... IE the process from wetsanding the cast parts up to the final finishing. I want to purchase a bench grinder of some sort if someone would recommend what I should get. Also, as for that bracket... and the other pieces for that matter... do you think it would be both less time consuming and less expensive to chrome plate them with one of caswell's kits. I'd really rather polish them because I know that learning how to do it in the long run will save mucho money. Please provide more input if possible. Thanks, TCalYen |
If you want to know more about the polishing, go to the Caswell site and download the buffing/polishing manual. It's free and gives you a good idea and what you need to get to get started. Buying the chrome kit is a good idea and will save you money in the long run, but it is much more difficult than it sounds. If you need a quick turn around, this is not a good option for you. I have been trying to plate for 3 months now and I still have a long way to go. The good thing is, once you learn it and get it down, you can save a lot of money if you have a lot of things to plate. You might be able to do it as a sideline to make some extra money, but be prepared to have alot of patience and time.
![]() Thanks, TCalYen |
Thanks for the replies... I read the manual...
Tell me if I'm right or wrong here. I'm going to buy a bench top buffer... at least 6amps and able to handle 6" wheels. Any suggestions on what brand and model to get... I don't want to spend that much money on this. Are the following specs suitable ![]() 8" Electric Bench Grinder & Buffer Voltage: 110 Volt Frequency: 60 Hz No-Load: 3450 rpm Motor: 1 HP 8.2 Amp 1 Phase 3/4" Arbor I'll take the parts I want to polish, wet sand from 150 grit all the way up to 600 or so using some combination of "sanding solution" other than water. What kind of sander should I use for this step? I'll get two or three (?) sisal 6"ers and some black compound (how much?) and go at it. How do I know when to move onto the next step![]() Then I'll get two spiral 6" wheels and some brown compound (how much?) and go at it again... How do I know when to move onto the next step![]() Then I'll get two loose cotton 6" wheels and some rouge compound (how much?) and go at it again... From here, what do you do? Just clean and seal with Zoop or something similar ![]() Oh, and should I get 4" wheels or 6" wheels ![]() And one last question... what do you all clean your pieces with inbetween steps ![]() Thanks for all your help. If you could offer you input on this that'd be great! I can't wait to get started. TCalYen |
Bump...
Can anyone confirm and answer my latest questions... It'd be appreciated. I'd like to order the grinder, wheels, and compound ASAP because I have a bunch of shows coming up. (See post before this one.) Thanks, TCalYen |
PLEASE HELP with QUESTIONS BELOW. I don't wantto buy the wrong supplies...
Thanks Quote:
| Any other powder coating forums around? | Bud | Powder Coating Questions | 1 | 06-07-2005 10:33 AM |
| NEED HELP QUICK!!! Yellow Zinc Plating Fasteners | BryanD | Electroplating Questions | 1 | 05-01-2004 01:34 PM |
| Quick question... wasn't sure where to post it. | TCalYen | Other Metal Finishing Questions | 0 | 04-26-2004 09:44 AM |
| New here, couple of quick ones (yes I read the manual! :-) | Stryder | Metal Polishing Questions | 22 | 12-15-2003 06:59 PM |
| Why no Tech Support on open Forums?? | Tim Wiltse | Electroplating Questions | 1 | 03-20-2003 02:48 PM |
