Old 04-19-2004, 08:49 PM
clockman
Default polishing 6061 aluminum w/bad results
I am cutting pieces of t-6061 into different shapes and trying to
polish it. tried sisal wheel with emery and did not like it. i get better results with brown and spiral sewn wheels. the metal is already smooth
and sanded out scratches with 320 grit and tried to polish it to a mirror
finish. the black really scratched up my piece. with the brown/spiral combo
the results are good in some places and bad (brown and hazy) in others.
then the white seems to dull it. i am using a double shaft 1hp 9amp
3450rpm motor it does not bog down. can anyone suggest how to get out the bad spots and create a mirror shine?
Old 04-20-2004, 06:37 AM
customandsound
Guest
Posts: n/a
don't use the black sisal combo ...on soft metals i use black on a sprial ... then the brown followed by white all on a sprial ...... sisal is a hard rope like stuff and it scratches to easy on the softer metal ..... give that a try
Old 04-25-2004, 10:13 AM
clockman
thanks customandsound am going to give it a try
Old 04-25-2004, 06:45 PM
customandsound
Guest
Posts: n/a
let me know your out come .... thanks
Old 04-27-2004, 09:32 PM
clockman
Default still bad results
i have tried emery then tripoli then white. it seems that when i start to get out all of the scratches i have pits. then as i am getting out yhe pits i form new pits in a different direction. i have raked my wheels and it still does the same thing. i have this so close to a mirror shine then the pits appear. why?
Old 04-28-2004, 09:08 AM
customandsound
Guest
Posts: n/a
that there would be gas in the metal ... little pin holes that form during the casting or forging of the metal .... the worst part about that is the some times you can sand them away ..but they can get out of hand to .....
Old 05-16-2004, 05:41 PM
skiddz's Avatar
skiddz
clockman, try rotating your direction of polishing 90 degrees between compounds. That'll helpt reduce scratching and pitting. Also, make sure you clean the part THOROUGHLY between compounds. There's no better way to scratch up a piece than by contaminating your finer grade wheels with leftovers from the lower grade process.
I've been using 50:50 Castrol Super clean and HOT water for the initial clean, then regular old dishwashing soap (Dawn/Joy/Palmolive etc..) with HOT water, then I wipe dry with a clean chamois cloth before moving to the next step.
why brown before white polishing aluminum? PRO'S PLEASE READ insomniac71 Metal Polishing Questions 9 05-24-2008 01:08 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
input on aluminum polishing and need help choosing a buffer Sid03 Metal Polishing Questions 7 08-09-2004 10:21 AM
Bad Polishing Results kenykirschstein Metal Polishing Questions 4 01-08-2004 05:27 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 08:12 AM
