My friend and I are retired electronics techs who still like to build things. We have a large supply of copper coated fiberglass board used for making printed circuits but it needs cleaning. The copper in question is one ounce to two ounces per square foot, so it's not very thick. The scrubbing pad method of cleaning also removes a lot of copper and is a lot of work. There must be a quick and efficient method to clean a copper surface and I'm quite sure that this is the place to ask about it.javascript:emoticon('
that is to thin to be putting on a bufer ... you can try a rotary tool with some red compund at low speed ... my dremel got a dimmer hooked in line so i can make is go super slow or full setting ....you may want to do a search on google to or contact caswell by phone !!!!!!!
Try the Brown compound for very severe oxidatiion.
The Blue is good for the normal stuff. I've always used #000 or #0000 steel wool, or the substitutes, for my final prep. I did a test, and this looks better than anything I've tried. Thanks for the idea. Only light pressure is needed. And, of course, clean the board with acetone afterword. |
Tomato Ketchup! But don't put it on your fries afterwards!!!
Make sure that whatever you do, you do it uniformly, otherwise, the copper won't etch right. I've had a lot of succes with mothers mag & aluminum on copper. It takes the tarnish off with no problem and leaves a nice shiney finish.
| Flash Copper Problem | gwjohnso | Plating Pot Metal | 12 | 02-27-2007 11:41 PM |
| I did a dumb thing - now how do I remove copper plating? | Mark3316 | Other Metal Finishing Questions | 0 | 05-19-2005 02:57 PM |
| Strike Copper or Acid Copper over Nickel? | mdarr | Electroplating Questions | 2 | 07-13-2003 01:53 AM |
| Strike copper or bright copper after zincate? | mdarr | Electroplating Questions | 2 | 06-29-2003 02:23 PM |
