I started playing around with some greaseless compounds in order to sand some aluminum welds after grinding them down.
I used the 80 grit with a 4" wheel on a variable speed hand grinder. I applied the compound and then allowed it to dry before using. What I found was that the compound sat on the surface of the wheel only, when I used it I didn't get a lot done before I had to reapply more compound. I found that lower speeds worked better. I had expected it to last longer. Is this typical
| I think I'm gonna try greaseless! But I need some info | rides20 | Metal Polishing Questions | 7 | 07-19-2005 10:59 AM |
| Is greaseless cheating? Plus a ? | berad001 | Metal Polishing Questions | 7 | 06-14-2005 03:05 PM |
| How do you use greaseless? | gagnon | Metal Polishing Questions | 3 | 03-21-2003 06:43 PM |
| Greaseless Compounds | zx7rwinered | Metal Polishing Questions | 1 | 10-05-2002 01:06 PM |
| greaseless compounds | saiyan7 | Metal Polishing Questions | 4 | 04-12-2002 08:29 PM |
