Old 05-02-2004, 05:38 PM
berndog will become famous soon enough
Send a message via MSN to berndog Send a message via Yahoo to berndog
Default flat aluminum
I amstill having trouble with Flat aluminum. I cut with tripoli,clean off with thinners,then go to untreated white airway wheel with green rouge,,,I get a nice shine,,but have lines cloudy hazy lines.is it my wheel? or speed of buffer,,,,I use a dewalt 1000-3000rpm polisher,,any help would be greatly appreciated
Old 05-16-2004, 05:33 PM
skiddz's Avatar
skiddz
You want to get your wheel speed to around 5,000 Surface Feet Per Second with aluminum. You may not have enough wheel speed depending on what size wheels you're using.
Also, adding a little compound quite often works better than adding a lot of compound infrequently. The wheels should not be depositing compound on the part as you work.
Also, try turing your direction of polishing 90 degrees to the last compound. That'll help with scratches and the hazing.
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Do you have to use flash copper to plate aluminum krsimulis Electroplating Questions 1 07-27-2004 01:32 PM
Cleaning Oxidized Aluminum With Sand Blasting Media? freematt Other Metal Finishing Questions 2 02-23-2004 02:22 AM
flat aluminum berndog Metal Polishing Questions 5 11-24-2003 08:53 AM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 01:19 PM
