Old 05-19-2004, 07:01 AM
chrisk
Default pimpling surface, please help
Im currently trying to polish up a set of porsche Fuch wheels. I stripped the paint that was on with nitro moors paint striper and found a rough surface with some kind of greyish coat underneath (anodising?) anyways i put a few greasless wheels on it till i got a respectable finish and hit it with brown, thing is the surface came up all pimply and uneven. Went back to greasless in case it was like that and didnt notice due to scratching and brought it back up but same thing happens. What causes this? is this from gases in the alloy, or am i doing something wrong? high speeds? checked warmth of surface, dosnt seem like i made it too hot though.
Old 05-19-2004, 12:11 PM
skiddz's Avatar
skiddz
I had a similar problem when I was sanding out the skid plate for my Banshee. No matter how I went at it, the surface would "orange peel" when I was working the part with 400 greaseless. I ended up having to hand sand the thing with 220 wet/dry, then 320, then 400 before I could start polishing.. The only thing I can think it might have been is just crappy aluminum..
Old 05-20-2004, 04:00 AM
chrisk
thanx 4 the heads up
resorted to hand sanding too or wheels in a drill running very slow.
A smal test section came up a dream
That anodizing is a real bitch to get off though
Old 05-22-2004, 12:13 AM
skiddz's Avatar
skiddz
Anodizing is easy to remove chemically. Lye based oven cleaner works great and Caswell sells some chemical stripper here. Trying to sand it off takes forever...
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Sand blasting media to use for surface prep tavo1765 Powder Coating Questions 13 03-18-2005 11:58 PM
Anodizing without knowing surface area? sbpoole Anodizing Questions 3 01-06-2005 07:09 PM
Silvaspray on a primered surface mdarr Electroplating Questions 0 10-23-2003 04:36 PM
Surface Area vs. Current shorton Electroplating Questions 3 11-06-2002 11:36 AM
