  #21 (permalink)
Old 06-21-2004, 09:46 AM
Shawn60
Just found out this tank is made of carbon steel. I'm thinking my results have sucked so far because I started with a spiral wheel and emery. I think I need to get a sisal wheel with some greaseless to do some major cutting following sanding.
  #22 (permalink)
Old 06-21-2004, 03:16 PM
skiddz's Avatar
skiddz
Steel is an entirely different animal when it comes to polishing. Sanding steps are basically the same, it just requires more effort and more time to acheive the smooth satiny finish.
The initial polish on steel should be a sisal wheel and emory (black) compound. Follow with a tight spiral/brown, then loose/white.
Don't use greaseless compounds with a sisal wheel. Use a tight spiral wheel and it'll work great.
  #23 (permalink)
Old 06-21-2004, 09:52 PM
Shawn60
Default Ahaaaa, said the blind man as he picked up his hammer &
Which will do more scratch removal, sisal/emery or spiral/greaseless? Also, some say to use this green compound, specifically made for steel, what's the difference between that or going the spiral/tripoli and loose cotton/white route?
  #24 (permalink)
Old 06-22-2004, 01:00 AM
skiddz's Avatar
skiddz
Hand sanding will go the furthest towards scratch removal. if the tank is kinda battered, I think I'd probably start with 400 greaseless on a tight spiral, get the tank smoothed out with that then dive into the wet-sand with 400 and possibly 600 until scratches are gone.
If it's not too bad, dive in with a sisal/emory and see how it comes out. You might have to hand sand a few small areas again, but the sisal/emroy should work pretty well.
As for the green, my bad.. I had aluminum on the brain and forgot a step. hehe
For steel I do sisal/emory or treated spiral/emery to start, then tight spiral/tripoli, then spiral/green and finish up with loose/white.
best way to figure out a method that works for you is to experiment. My way isn't the same as customandsound's or anybody elses, but we all get good results. Trial and error (mostly error when you're first starting out hehe) will get you a good result in the end.
  #25 (permalink)
Old 06-22-2004, 01:19 AM
customandsound
Guest
Posts: n/a
Shawn60.
from what i found on polishing steel it dose take longer and you can get a nice results from it to ...
i sand like i do on alum.. when i get in the wet sanding i use 220 right up to 2500 grit wet at this point you should have a nice shine going .. double stack siprial load it with brown and got 2 pass's in the cut motion and 4 passes in the color motion .... then i triple stack losse cotton and load it with green and do the same . then swithc over to 3 losse 10" load white then hit is til you see that there is a nice shine ... this stage is where i get all the fine little scratches out ... then if you want you can hit it with red it is more less a color compound that bring's out the shine ... give it 3 good coat's of wax buff it anf you got a nice chrome look
  #26 (permalink)
Old 06-22-2004, 08:03 AM
Shawn60
Default Mostly error he he
You got that right Skiddz I've got a sisal wheel on the way, we'll see how that works for me. It keeps getting better every time I go over it again but like I said before, patience is not a virtue I can claim Really appreciate all the advice guys.
  #27 (permalink)
Old 06-22-2004, 12:11 PM
Shawn60
Hey, how does carbon steel compare to stainless? Will the recommended buffing compounds be the same for carbon?
EDIT:
Success! And about bloody time too. Got my 2 sisal wheels today and that was the ticket. Spiral wheels won't do jack on carbon steel even loaded with emery. I should be posting pics in the next day or two. Just wanted to say thanks to everybody for all the advice given. This board is great.
  #28 (permalink)
Old 07-03-2004, 12:08 PM
Shawn60
http://members.cox.net/daniels30/Pub...s/page0003.htm
Bottom right corner of the page shows my tank. Thanks for all the advice gentlemen!
Okay, why can't I get a picture to post?
  #29 (permalink)
Old 07-03-2004, 12:48 PM
skiddz's Avatar
skiddz
Pics are easy to post. Just click the "Img" button up top, type in the *EXACT* URL (it's case sensitive!) to the pic and then click the "Img" button again. The pic you want to post has to be out on the web somewhere. (unless you're running some type of web server outta your house - which most ISPs frown upon)
The bike looks nice BTW.
  #30 (permalink)
Old 07-03-2004, 06:39 PM
Shawn60
Thanks Skiddz. Saw some shots of your Banshee from your home site, very nice work on the cases and carb. You crack me up with the 'how to make a 2" sisal from a 6" ' post. Thanks for the tip on posting pix. Still having problems with posting the pic, getting aggravated. I am copying and pasting so I don't see how there can be any errors. Anyway, here is a link to my bike page http://members.cox.net/daniels30/Pub...s/page0001.htm
You don't stop riding because you get old, you get old because you stop riding
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 03:03 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
Need opinions on my next tank. jtsuttle Anodizing Questions 4 03-29-2004 01:32 PM
Other materials in Anodizing tank? usao Anodizing Questions 4 03-04-2004 10:07 PM
Tank Heating Questions. meganine Anodizing Questions 1 08-03-2003 04:20 PM
