+ Reply to Thread
Results 1 to 3 of 3
Thread: Buffing speeds & flex shaft?
  1. Buffing speeds & flex shaft?
    I ordered the wheel polishing kit and the Zoop seal, and I read through the online buffing booklet, which states:
    "For best results your wheel should maintain a surface speed of between 3600 & 7500 surface feet per minute (SFPM).
    SFPM = 1/4 x diameter of wheel x RPM"
    Why is it 1/4, wouldn't it be Pi (3.14) x Diameter x RPM? Just curious...
    Anyway, it seems that a grinding wheel is a good choice, so I will borrow a friend's Craftsman grinder. I can't imagine not using a flex shaft to polish 18" car wheels with this, but no one seems to sell them for bench grinders. Surely someone has them? I have a Rotozip too, but it runs at 24,000 RPM I think...would that work as well?
    Share with Facebook
  2. Join Date
    Dec 2003
    Location
    So. CA
    Posts
    254
    Your formula is correct. Pi times diameter times RPM will net you a correct SFPM. For aluminum, shoot for right around 5,000 SFPM. A 6" wheel at 3450 RPM will get you up around 5,400 SFPM which is right in the ballpark.
    I cobbled up a SFPM calculator with javascript and put it here:
    http://users.adelphia.net/~skiddz/Wheelspeedcalc.htm
    It's ugly and kludgy, but it works. :)
    There are flex shafts out there that you can run from your buffer. I've got one I run off my Jet 1hp buffer and it works great. I don't think the RotoZip would have enough torque to be very effective at buffing. I've also got one of these things and other than sink cutouts and the occasional oddball drywall cutout, it's pretty useless IMO. :)
    Share with Facebook
  3. Re: Buffing speeds & flex shaft?
    Quote Originally Posted by Tallman
    [img]
    The long form is (Dia. X Pi) / 12 x RPM = SFPM
    Dia. and Pi are in inches. Dividing by 12 converts it to feet.
    For general purpose Pi / 12 is simplified to 1/4.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. "optimal" wheel speeds
    By skiddz in forum Metal Polishing Questions
    Last Post: 01-27-2004, 02:29 PM
  2. flex shafts
    By shine in forum Metal Polishing Questions
    Last Post: 11-08-2003, 01:54 PM
  3. Question about buffing speeds
    By jhearn in forum Metal Polishing Questions
    Last Post: 05-14-2003, 08:18 AM
  4. flexable shaft polishing
    By sparts in forum Metal Polishing Questions
    Last Post: 05-09-2003, 10:01 AM
  5. buffing direction
    By hue in forum Metal Polishing Questions
    Last Post: 02-23-2003, 10:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
