+ Reply to Thread
Results 1 to 5 of 5
Thread: large part finish?
  1. large part finish?
    what kinda tricks do some of you use for getting a finish shine on large parts..im talking large stainless firewalls, aluminum gas tanks..ect.ect.. i am doing fine getting the shine out of it with black/tripoli compound. but when it comes to using white on a large piece it wont bling like other parts.
    im also having a hard time with track lines from the pass before...i was wondering if i can use my car buffer with a foam/wool/cloth pad using the caswell liquid white would work or not.
    if any of you live around the area and want to see some of the rad rides id did come to the goodguys show this weekend..
    this is my first post here i know.. but i mostly read the problems you all are having.
    im really suprised with the way the "secret to polishing" has come out of the woodwork. 5 years ago..no one would even give me a hint on how to begin polishing. and i had to figure it out on my own. this web site is nice for the beggininer.
    thanks for the help in advance.
    chris
    r-b custom metal polishing
    columbus, ohio
    Share with Facebook
  2. Join Date
    Dec 2003
    Location
    So. CA
    Posts
    254
    There's a secret??? I've been here for MONTHS and nobody's told me about it! ehehhe
    For large flat parts, I stack up to 4 wheels on my buffer at a time so I get a BIG footprint. I make multiple passes with each compound/wheel combo and vary the direction each pass.. For the final loose/white color step, I do a minimum of 3 passes, varying the direction each time.. It's a lot of extra work, but the results come out nice.
    Share with Facebook
  3. and you dont get any track marks from the pass before?
    Share with Facebook
  4. Join Date
    Dec 2003
    Location
    So. CA
    Posts
    254
    Nope.. Seems to work pretty well.. Make sure you overlap your passes and vary the direction. For example, I'll do the 1st pass parallel with the long dimension of the part. I'll do the next pass at 45 degrees to the left, then the last at 45 degrees to the right.
    Occasionally I'll see some lines and I just touch 'em up.
    I've had parts that refuse to really brighten up unless the pass was done in a specific direction and only in that direction.
    Watch your working pressure. Don't push too hard on that last step. Let the wheel and the compound do the work. Apply a little compound (a second or two) every few seconds (20-30) and it should work well.
    Share with Facebook
  5. cool thanks man.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Need Silvaspray/Chrome/Brushed Nickel Finish on Plastic Part
    By vatik in forum Services Offered/Wanted
    Last Post: 07-29-2005, 05:15 AM
  2. Golf Clubs - How to remove nickel finish prior to refinishin
    By doctordave in forum Other Metal Finishing Questions
    Last Post: 06-03-2005, 03:21 PM
  3. removing zinc
    By modadds in forum Electroplating Questions
    Last Post: 04-11-2005, 01:13 AM
  4. Newbie, trying to find best way to finish aluminum-LONG POST
    By chik in forum Metal Polishing Questions
    Last Post: 03-14-2005, 08:11 PM
  5. can we identify this finish?
    By funkmunky in forum Electroplating Questions
    Last Post: 12-15-2004, 08:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
