Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Closed Thread
Old 07-25-2004, 04:33 PM
clockman
Default cannot remove scratches
i am polishing 1/8 thick I think 6061 aluminum . The finish with emery is pretty good then I switch to tropoli compound then to white. I even bought some special compound from caswell and tried it. I still have a scratched surface after i color the part they are much finer than with emery or tripoli. I have even tried to polish this aluminum without sanding and using white and can cut and color it but still have scratches. Could this aluminum be to soft or getting to hot? I am using new wheels and i am keeping them all closed up and seperate. i am so dissappointed in the results and there is no one around here that polishes to show the results to to get any answers. Should I go to thicker marterial to try to reduce the heat?
Old 07-27-2004, 01:19 AM
customandsound
Guest
Posts: n/a
with a soft metal like that Don't use a sisal it wil tear it up ... you can give this a try :
1. wet sand up to 2500 grit
2. sprial /green color motion
3. loose / white colot motiom
4. loose /red
the black is to coarse you be used on soft metal's.. and as the metal heat's it get's softer than before ... and that is where the fine scratches may be coming from
Old 07-30-2004, 11:43 PM
clockman
Default thanks customandsound
i will try this but i have a green compound i think jewlers rouge. i thought it was finer than white and where do you get the red. is the green you are talking about jewelers rouge? you have been a big help
Old 07-31-2004, 03:11 AM
customandsound
Guest
Posts: n/a
Default Re: thanks customandsound
green is not jeweler's red is ... you can order a starter kit from caswell that got black,brown,green,red,blue,white compound
Old 08-01-2004, 10:51 AM
rotorman
green is also called stainless compound.
I've heard it can be very good on alloy.
Blue is meant to have no cutting action. I don't think it will remove any of your scratches, all it may improve the colour (reflectiveness) of the surface.
Old 08-01-2004, 09:13 PM
customandsound
Guest
Posts: n/a
blue is more less for chrome and can be used on a loose or a sprial ...
Closed Thread
I did a dumb thing - now how do I remove copper plating? Mark3316 Other Metal Finishing Questions 0 05-19-2005 03:57 PM
Stainless steel Scratches SP4SPD Metal Polishing Questions 7 01-12-2004 09:42 PM
removing scratches and restoring shine? Augest Powder Coating Questions 2 01-02-2004 10:00 AM
How Do I remove tiny, light scratches from Aluminum? chem_man3 Metal Polishing Questions 17 03-04-2003 12:46 PM
using talc to remove scratches ghiggs Metal Polishing Questions 1 11-01-2002 09:51 AM
