+ Reply to Thread
Results 1 to 3 of 3
Thread: brass polishing
  1. brass polishing
    i am trying to learn how to polish brass and copper. I am using a 1hp buffer at 3500 rpm. i have been starting with a black compound with a sisal wheel and going through brown white and finally a red rouge. after my final polish prior to clearing i am seeing very small lines that are only amplified by the clear coat. what am i doing wrong and why cant i eliminate these lines. any help would be greatly apreciated.
    frustrated
    Share with Facebook
  2. customandsound Guest
    Stop!!!!!!
    you Don't want to use a sisal on soft metals ... it will tear them up ...
    use this step ....
    brown/sprial
    green/loose cotton
    red/loose cotton
    if you are still getting scratches
    white/loose
    then the green then the red
    Share with Facebook
  3. What about speed
    I was told that 1800 RPM is appropriate for polishing brass and that 3450 is too fast. Does the thickness of the brass matter. What about wheel diameter. If I can pick the wheels and machine.... is a larger diameter wheel and a slower buffer the best combination?
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Something for you die hard polishers out there to chew on
    By thesound in forum Metal Polishing Questions
    Last Post: 12-03-2007, 12:16 PM
  2. Polishing brass to hold crisp edges
    By gcmichael in forum Metal Polishing Questions
    Last Post: 05-15-2004, 12:36 PM
  3. polishing a brass lamp
    By artp in forum Metal Polishing Questions
    Last Post: 02-02-2004, 11:13 AM
  4. Clearcoating brass after polishing
    By skipmac in forum Metal Polishing Questions
    Last Post: 10-04-2003, 08:58 AM
  5. Brass Polishing
    By breckrider in forum Metal Polishing Questions
    Last Post: 12-04-2002, 08:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
