i have tried the great advice given me and still have questions. could i have a buffer running to fast? i have sanded my pieces and tried to buff them and am getting pits in my pieces before i get all of my sand marks out. i am using a craftsman power tool motor rated at 9 amps and 3650 rpm. i also use 8" wheels and. i cant use 6" wheels on here because my shafts are not long enough to clear my motor. is the speed causing to much heat and that causing the pits?
Perhaps the pits might actually be pin holes in the material. What material is it you are trying to polish? I have found that sometimes when I polish various types of steel before platting, (stainless, cold rolled and hot rolled and pickled ) there are very fine pins holes all over the place. That is why I got the plating set up to help get rid of these.
Hi, I'm new here myself but I can answer this one.
I just finished a Norton side cover which had these pores. It's due to less-than-perfect manufacturing of the metal. No amount of grinding or polishing will remove them because you only expose new ones as you remove material. The best you can do is to make a glaze over the pits with rouge. It will look quite acceptable from a few feet away, but the dimples will remain. Also, when polishing, the pores will suck the compound right off your wheel, so you need to overload it more than normal until the wheel begins to cut. When you clean between grits, use Fantastic or 409 a few times then Dawn detergent, to lift the grit out of the pores. Rinse well. Good luck. Quote:
| HELP WITH GETTING OUT PITS IN ALUMINIUM WHEELS!!!! | johnnyb | Metal Polishing Questions | 10 | 04-27-2005 11:34 PM |
| Newbie, trying to find best way to finish aluminum-LONG POST | chik | Metal Polishing Questions | 6 | 03-14-2005 08:11 PM |
| can we identify this finish? | funkmunky | Electroplating Questions | 3 | 12-15-2004 08:45 PM |
| filling small pits with acid copper | danderson | Electroplating Questions | 2 | 08-25-2004 07:55 AM |
| dull finish on old bolts with rust pits | fordmerc | Electroplating Questions | 1 | 02-15-2004 04:22 AM |
