Old 09-03-2004, 01:04 AM
squaredealer
Default Sanding
Starting my first project. Was inspired by SYCO i guess. Anyhoo... Stripped the Harley paint off an aluminum piece. I used a metal stripper that worked well using a wire brush on my drill. Had to modify a 1 inch brush down to about 1/4 to get in the crannies. Ok, so figured out how to get in the tight spots for paint removal. How about sanding? I have a Dremel, but even those little sanding barrels are too wide. Any thoughts would be appreciated.
Old 09-03-2004, 01:17 AM
customandsound
Guest
Posts: n/a
glassbead and a lot of elbow grease you will get this:
Old 09-05-2004, 01:37 AM
Zouky
Is that chrome plating?
Thanks,
Andy
Old 09-05-2004, 09:06 AM
customandsound
Guest
Posts: n/a
nope.... it was sand blasted then bead blasted to remove the old finish that was chipping and flaking if you look at the arear that have covers they are not shinne unless they got hit wit a buff
Expander Sanding Wheels. jrow Metal Polishing Questions 2 07-25-2005 11:10 AM
sanding? randygrapes218 Powder Coating Questions 3 03-06-2005 12:32 PM
Sanding drum grits finer than 120? jhelm Metal Polishing Questions 3 01-25-2005 12:47 PM
streamlining sanding of cast aluminium parts rotorman Metal Polishing Questions 6 05-22-2004 12:09 AM
Sanding questions for tight spaces 8mpg Metal Polishing Questions 6 02-07-2003 02:23 PM
