Old 09-10-2004, 03:35 PM
buffadiddle
Default Help! Weird 2-Toned Finish on Aluminum
Here's the deal.....
I'm getting this strange 2-toned finish on aluminum.
It starts to appear somewhere between 320 to 600, during both wet sanding or steel wool,
before I move to the buffing wheels.
see picture
It stays like that all the way through the three buffing wheels.
What is this?
What's causing it?
What can I do to correct it, and/or stop it from occurring?
Thanks!
Mike
Old 09-10-2004, 07:11 PM
customandsound
Guest
Posts: n/a
that is the layers in the metal it is a bad casting you may be able to blend them in some more
Old 09-10-2004, 10:16 PM
buffadiddle
I think the piece is made from round stock, approx. 7/16 inch diam. Is that still cast aluminum?
In any case, any tips on blending? Should I level sand until I remove the top layer?
Thanks again,
Mike
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Newbie, trying to find best way to finish aluminum-LONG POST chik Metal Polishing Questions 6 03-14-2005 08:11 PM
How do I get a mirror finish on Aluminum JayPressimone Metal Polishing Questions 3 03-05-2005 12:44 AM
Need mirror finish on 2025-t3 aluminum playwphyre Metal Polishing Questions 0 09-25-2004 01:02 AM
Which Clear finish for polished aluminum? wedwards63 Other Metal Finishing Questions 2 05-12-2003 11:02 PM
