Hello, I'm new here. I tried a search before posting, but I did'nt find anything.
I will be polishing all trim work on my car, but will be starting with the trim around the windows. On my 77 Mustang II. How do I tell if it is aluminum trim or stainless steel trim? From what I have learned so far from searching this forum, there is different polishes and methods to polishing either aluminum or stainless, is that right? Thank you for any help. |
there is non magentic stainless out there
but here is what you can do : wet sand with 600 - up to - 2000 buff with white on a losse cotton.. if i get a chance today i will tear a part off the junker in the back and polish it up.. wait better yet green on sprial white on loose than should give you a shine that you want |
stainless is not magnetic to my knowledge. you can tell by shooting a tig torch at it on dcep- if you get a nice pool, it's stainless. if it just looks nasty and spatters, it's aluminum.
another way to test it to try and drill a hole in it or mill it or just scratch it. aluminum is soft, stainless is relentless in hardness. |
customandsound: Ok I am working on a trim piece, started with a small section about 1 foot long.
I did what you said with the wet sanding. I don't have all the green on loose or white on spiral stuff. I am using Mothers aluminum and metal polish, with clean, white 100% cotton t-shirts. Starting with a clean section everytime. I'm doing something wrong!! I wet sanded about 3 min. each with each grade of sandpaper. Remember the section I'm working on is only about a foot long. Do I need to sand for a longer time with each grade? I then took the piece inside and started polishing. I have polished in that one spot for 4 hours. It's got a shine to it, but not good enough, I want it to look like a mirror when it's done. And heres what blows my mind. After all the wet sanding, after 4 hours of polishing. I start with a clean section of rag everytime, as soon as I start to rub, the rag instantly turns black, dark black, everytime. What am I doing wrong, please help. I could be 65 by the time I get this stuff polished. |
can you email me your phone # or call me
customandsound@yahoo.com my phone # is on my webpage www.customandsound.com |
| why brown before white polishing aluminum? PRO'S PLEASE READ | insomniac71 | Metal Polishing Questions | 9 | 05-24-2008 02:08 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Stainless hardware | mudwhump | Anodizing Questions | 5 | 01-12-2004 11:05 PM |
| Stainless or Aluminum | fredetl | Metal Polishing Questions | 2 | 07-17-2003 09:58 PM |
| Aluminum damage | kiwigips | Other Metal Finishing Questions | 1 | 06-16-2003 11:03 AM |
