Old 09-25-2004, 02:02 AM
playwphyre
Default Need mirror finish on 2025-t3 aluminum
I am trying to polish a flat piece of 2024-t3 aluminum to a mirror finish (i need to look at it under a microscope and can't see scratches) but have very fine scratchs. I have tried many things, including sisal with black, then sewn with brown, loose with liquid white, and canton flannel with red. I have used a drill press with 4" wheels as well as a 3/4 hp motor with 4" wheels, not sure about the rpms but the motor is much slower than the drllpress.
I have tried many different combinations of the above and clean the part in simple green or another degresser before the next step. Now even when i use the red, which is supposed to be jewlers rouge and have NO cutting action, it still will cause small scratches in the surface. I have tested this by polishing in different directions and the scratches always line in the direction of the spinning wheel.
Just to prove to myself it wasn't due to the wheels itself or contamination from the previous step, i tried polishing with no rouge added at all, and no additional scratching occurred.
If anyone knows any way to polish without scratching please let me know.
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
Do you have to use flash copper to plate aluminum krsimulis Electroplating Questions 1 07-27-2004 02:32 PM
Aluminum polishing help needed erikchow Metal Polishing Questions 1 02-25-2004 03:44 AM
Cleaning Oxidized Aluminum With Sand Blasting Media? freematt Other Metal Finishing Questions 2 02-23-2004 03:22 AM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 02:19 PM
