im polishing my aluminum motorcycle frame and wanna know..
how long do i.... 1) sand with each grit ? 2) polish with each wheel/compound 3) apply compound to the wheel and finally at what grit should i start/stop using a palm sander? should all grits be wetsanded? im using wd-40 to wetsand and find it to be good...is it ok? |
did you read the how to buff on caswell's site? theat would help answer most of you ? you have ... and i would use water for wet sand.... wd40 is great fro drilling and boring but just don't cut it ... the shaving sticks to the paper and you goo thur it quick
| Outgassing? How long | estevahn | Powder Coating Questions | 2 | 06-10-2005 10:32 PM |
| How long will the powder hold until it needs to be cured? | trsick | Powder Coating Questions | 13 | 03-14-2005 12:23 PM |
| Nickel Plating long tube | Gabourie | Electroplating Questions | 1 | 10-12-2004 08:02 PM |
| how long does it keep | inst2 | Electroplating Questions | 1 | 11-09-2003 05:40 AM |
| plating long pieces | rjh1936 | Electroplating Questions | 1 | 02-20-2002 01:04 AM |
