Old 12-21-2004, 08:51 AM
BRANDONPEAKE
Default STRIPPING PAINT OF METAL BEFORE POLISHING IT
i got a thumb throttle housing i need to strip the pain off of so i can polish it what are u guys using to do this with? ive got a wire wheel but im more looking for something to spray on it and get it off b/c of all the litle crevices and hard to get places in it
brandon
Old 12-28-2004, 03:14 PM
BigDog's Avatar
BigDog is on a distinguished road
I use media blast, if you pay the postage i'll blast it for free, let me know.
Jeff B
Old 12-28-2004, 05:39 PM
unless you use plastic media
I wouldn't use blasting cuz that means extra work
when polishing I always try to start with the smoothest surface possible
you can strip it down with AIRCRAFT paint remover and a hard toothbrush
wear gloves this thing is stings on your skin
Old 12-28-2004, 09:49 PM
BigDog's Avatar
Never had extra work using glass bead.
Old 01-04-2005, 11:12 AM
BRANDONPEAKE
would this tuff work?
http://www.caswellplating.com/vht/sp...stripper.html#
also where do u get the sircraft paint removal so i might can find it local?
Old 01-07-2005, 12:07 AM
customandsound
Guest
Posts: n/a
glass bead hit with a sisal and emery to even it out and then hit it with white on losse ..... i do all mine that way and never had any problems
Old 02-04-2005, 01:32 AM
berad001
wait.. so you're hitting it with glass bead then just polishing it? Are you doing anymore sanding? Is this glass bead media you're hitting it with wet blasted or dry?
  #8 (permalink)
Old 02-05-2005, 12:25 AM
customandsound
Guest
Posts: n/a
I hit the last ones i did with glass bead lightly sanded the tore up a sisal. the thumb thottle should take you no more than 20-45 minutes to complete
transparent paint after polishing Pol3000 Metal Polishing Questions 4 04-23-2005 07:18 PM
New to the metal polishing thing customandsound Metal Polishing Questions 13 01-02-2004 08:08 PM
Stripping paint from Hood Hinge mdarr Electroplating Questions 3 07-30-2003 03:01 PM
Paint Stripping damnedin82 Electroplating Questions 0 03-06-2003 09:36 PM
polishing metal gopedhead Metal Polishing Questions 8 04-30-2002 05:33 PM
