+ Reply to Thread
Results 1 to 5 of 5
Thread: Polishing Aluminum Wheels With Dremel
  1. Polishing Aluminum Wheels With Dremel
    i am trying to polish my wheels and have a couple questions. Is a copper wire brush ok to use on aluminum and will it smooth it out any? How do i wet sand in the creases between the spoke and the edge of the rim? How do you use polishing compound with the felt and cloth pieces? Thanks, Kyle
    Share with Facebook
  2. somebody has to have experience polishing aluminum.
    Share with Facebook
  3. customandsound Guest
    Re: Polishing Aluminum Wheels With Dremel
    Quote Originally Posted by bluews6
    why would you use copper wire brush on aluminum ?
    i would reccomend that you read this : http://www.caswellplating.com/buffs/buffman.htm
    it will help you out some ......
    Share with Facebook
  4. seems youre way off on this. Firstly a dremel aint really up to the job. Secondly you need cloth polishing wheels and special polishes rather than brushes. Caswell do wheel polishing kits on their site designed to be used with a hand drill or polishing machine and flexi shaft. Once you have those the guide mentioned above will explain how to use the kit to get great results
    Share with Facebook
  5. Re: Polishing Aluminum Wheels With Dremel
    Quote Originally Posted by customandsound
    I am only using the dremel to polish the awkward places on the wheel. This is the write up i read to polish wheels.
    http://www.78ta.com/rims.htm
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Something for you die hard polishers out there to chew on
    By thesound in forum Metal Polishing Questions
    Last Post: 12-03-2007, 01:16 PM
  2. Need help polishing my polished aluminum wheels
    By suparida in forum Metal Polishing Questions
    Last Post: 09-02-2005, 10:08 AM
  3. Need Help Polishing aluminum Wheels.
    By mattyp in forum Metal Polishing Questions
    Last Post: 06-14-2004, 09:44 PM
  4. A ? regarding polishing aluminum wheels...
    By geotexZ71 in forum Metal Polishing Questions
    Last Post: 04-25-2003, 09:12 AM
  5. Polishing aluminum motorcycle wheels
    By emprcyrul in forum Metal Polishing Questions
    Last Post: 02-15-2003, 11:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
