I am trying to sand my wheels to get them as smooth as glass and i went through all the grits and when i started wet sanding with 1500 grit it still scratches the metal. I tried the 1500 both wet and dry with no luck, and still cant get a smooth finish. Is there some trick to getting it perfectly smooth?
Do you have any buffing wheels and black/white compounds to use? Sanding alone won't achieve the "mirror" look that you see on all polished metals. If you've sanded all the way up to 1500 grit then you're more than ready to start in with the buffing wheels and compounds. As soon as you buff with the black emery compound, the scratches will disappear.
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| Machine to polish aluminum parts | Zouky | Metal Polishing Questions | 0 | 09-05-2004 01:40 AM |
| Recommend a good aluminum polish for my current situation! | qwik3r | Metal Polishing Questions | 1 | 05-04-2004 05:36 AM |
| Media to mirror polish Aluminum in vibratory tumbler | hrothgar | Metal Polishing Questions | 1 | 07-26-2003 11:32 AM |
| Aluminum Wheel prep and polish | patrickzeus20 | Metal Polishing Questions | 2 | 03-04-2003 12:00 PM |
