Old 01-30-2005, 04:27 PM
bikewhisperer
Default best method of keeping aluminum polished?
Hey all
I am currently polishing a bicycle frame made of 6061. It is a brushed finish and I am hoping to make it as shiny as possible. The best system I have come up with so far is wet sanding 1200 grit and then using the buffing wheels and compounds. My major concern is that after all this work it will look rough in a short period of time. Would anodizing be a good way to keep it from deteriorating? I want to keep the mirror finish so I assume either no dye or silver would be my only options. Maybe I am way off base here an just a good wax job will do. I'm sorta looking for an excuse to get set up anodizing, and I suppose a bike frame would not be a great first project anyway! Thanks for any advice.
Darren
Old 02-04-2005, 11:43 PM
customandsound
Guest
Posts: n/a
well you need to start some where ... good luck!! but all i can say to this one i would take time to read buffman topic.. lot's of tricks and tips :
http://www.caswellplating.com/bbs/viewtopic.php?t=526
to keep you shine i would coat it with carnuba wax or zoop it
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Need help polishing my polished aluminum wheels suparida Metal Polishing Questions 12 09-02-2005 09:08 AM
How do you clean your polished aluminum? mach1man Metal Polishing Questions 3 10-02-2004 02:42 PM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 01:19 PM
VHT-Clear or Glisten PC for polished aluminum protection? Great_Scott Metal Polishing Questions 5 04-08-2002 08:15 PM
