I am polishing some stainless steel "nose cones." These are used to cover controls on ice cream machines. These have a reddish coating due to heat treating. The manufacturing process leaves some lines on one side that have to be removed.
Am currently using a satin wheel to remove lines and coating followed by a medium buff using red compound to remove the satin lines followed by green compound for shine. This is taking a long time and we're not getting very good results. Am wondering if a sisel wheel would be better than satin. Stainless steel is very hard and think there should be a better way to work with it. Thanks!! |
Mboyd, you are correct, stainless steel is very hard, need the sisal wheel. I found this out when I tried polishing a gas tank on my motorcycle. All of your anxiety will go away with just a few passes on the sisal, trust me
You don't stop riding because you get old, you get old because you stop riding |
I believe Caswells sells a fast cutting stainless compound, and definitely use a sisal.
here is a link to that page http://www.caswellplating.com/buffs/compound4.html |
| Electro polishing stainless steel? | rpmlou | Metal Polishing Questions | 7 | 10-28-2005 08:53 AM |
| Polishing stainless steel MC exhaust mid pipes | kevinw1961 | Metal Polishing Questions | 3 | 05-22-2005 09:28 PM |
| Polishing Stainless Steel | RiverBoy | Metal Polishing Questions | 2 | 07-03-2004 10:44 AM |
| Polishing stainless steel exhaust headers | Thorsten | Metal Polishing Questions | 0 | 05-16-2004 11:52 PM |
| polishing stainless steel exhaust | getnbz | Metal Polishing Questions | 0 | 09-24-2003 08:19 PM |
