Old 02-06-2005, 07:56 AM
Default What am I seeing - swirl marks?
Hi,
My process so far has been greaseless 120/220/320, then spiral emery/loose white/loose red. I get a nice deep shine with no directional scratches.
BUT, when a point souce of light hits it (light bulb, reflection of the sun), it is full of microscratches in a circular pattern surrounding the point light source.
Tried the powder, no joy. Going to try the kerosene I read about in one post but in the meantime: what are swirl marks and how do you get rid of them?
Thanks
Mike
Old 02-06-2005, 12:25 PM
thesound has a spectacular aura aboutthesound has a spectacular aura about
Try going a little higher in grit range with your sanding before you start in with the emery. Most say 400 grit will suffice but I always go to 600 just to be safe. Those "swirl marks" that you're seeing are the scratches left by the 320 grit that the emery compound wasn't able to buff out because they were too deep.
Old 02-06-2005, 04:47 PM
Thanks. I'll buy that, although I have gone as high as 600 wet, with the same results. Perhaps I didn't give it long enough.
So, can anybody describe a true swirl mark for me? I assume they are not mythical since much literature mentions them.
Old 02-11-2005, 12:45 AM
customandsound
Guest
Posts: n/a
dump the sisal /emery and try sprial /emery then you will be fine
Old 02-15-2005, 12:15 PM
Thanx, but I generally don't use sisal on aluminum.
Old 02-15-2005, 08:20 PM
customandsound
Guest
Posts: n/a
this was done today sprial black and white loose ;
this was before i cleaned it and coated it with carnuba
Old 02-15-2005, 08:21 PM
customandsound
Guest
Posts: n/a
as you can see in the first pic the hazy that was just blow off sprial black
this pic is the finished
  #8 (permalink)
Old 02-17-2005, 09:05 AM
So the diff between the first and 2nd pic is just that it was cleaned and waxed?
  #9 (permalink)
Old 02-17-2005, 12:58 PM
customandsound
Guest
Posts: n/a
nope !!! i hit it with red on a loose then cleaned and waxed it ..
i only used the black sprial and red loose not other compounds
stretch marks and hidden letters eyekandi Metal Polishing Questions 3 08-08-2005 10:29 PM
Finishing question on frame.... bairdmotorcycles Metal Polishing Questions 9 06-09-2005 01:09 AM
Swirl marks? mpierich Metal Polishing Questions 3 12-21-2004 12:39 AM
Will abrasive blasting get rid of aluminum casting marks? liem921 Metal Polishing Questions 1 10-11-2003 06:15 AM
Blasting media for removing casting marks gottago_joe Metal Polishing Questions 0 06-01-2003 06:15 PM
