Old 02-28-2005, 11:33 AM
berad001
Default Need quick help with slices in aluminum
I recently got a part in that has some large slices in the finish. The biggest slice is about 2" long and maybe 1/8" deep. Is there a filler I can use to fill in the slices that will polish up with the aluminum, or atleast clean the look of the part up a bit? Any info would be awesome.
~Brad
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
using aluminum as a cathode scocklin Anodizing Questions 19 03-31-2007 12:18 AM
Do you have to use flash copper to plate aluminum krsimulis Electroplating Questions 1 07-27-2004 01:32 PM
Aluminum polishing help needed erikchow Metal Polishing Questions 1 02-25-2004 02:44 AM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 01:19 PM
