Old 03-07-2005, 07:41 PM
berndog will become famous soon enough
Send a message via MSN to berndog Send a message via Yahoo to berndog
Default glass blasting
I've been polishing poor shape Alcoa truck wheels for years now,,,always sanding poor ones from 80 grit up to 400,,,been wondering if anyone has ever tried sandblasting with glass,,or anything else & how does it turn out?
Old 03-10-2005, 11:19 AM
clydes is an unknown quantity at this point
blast them then da sand with 180 then go right to your buffing wheels they should turn out fine. works for me. clydes
Old 08-24-2005, 09:33 AM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: glass blasting
If you use baking soda in your media blaster there is no need to use sand paper this will leave a bright finish with out sanding and will not harm the piece you are working on
due to high heat sand can actualy burn items if you are not careful also sand or bead blasting can leave a dull or gray finish on the item that needs to be polished out before plating
I use soda on everything it works great with very little time at the polisher afterwards
sand blasting cabinet...relocated to tips n tricks section duke Powder Coating Questions 15 12-30-2007 11:28 AM
Sand blasting VS glass beating? monster01 Other Metal Finishing Questions 2 09-09-2006 08:28 AM
Sand blasting media to use for surface prep tavo1765 Powder Coating Questions 13 03-18-2005 11:58 PM
Looking for a MASKING product for blasting ops Halliwell1 Other Metal Finishing Questions 3 04-21-2004 07:23 PM
Respirator failed while blasting with glass bead... skiddz Powder Coating Questions 5 01-17-2004 01:36 PM
