I have a customer that has some old boat hand rails (round pipe stock). They look like they were previously coated with chrome or galvinized (the coating is so oxidized it's hard to tell). They are brass under the old coating. My customer wants the brass revealed & polished.
My questions are A: What is the best way to remove the old coating. I tried sandblasting (slow). I tried a DA sander, the coating came off pretty quick but the sander left flat spots on the round stock. B: After I sand or sandblast the coating off, what's the best way to get the brass to shine? I tried wet sanding (very laborous & slow). I tried a wire wheel, much faster, it was somewhat shiney, but not a real nice finish. So any advise will be greatly appreciated! I have a buffing pad mounted to a drilll? Also have a "Fliptz" ball & some compounds Thanks Bob
www.capecodpowdercoating.com |
I just did some chrome stripping on a set of hand levers. Ended up using a 120-grit setup wheel (spiral wheel, dip in glue then in grit) to remove the chrome, dropped back to 80 grit greaseless to even it out, then to 120/220/320 greaseless, then polished.
What do you think of the Caswell buffer kit (both 3/4 hsp. & 2 hsp.) Will that kit give me the tools to do stripping & polishing including brass? Also is the 2hsp. kit worth the extra $$?
Thanks Bob
Thanks Pickleboy:
I ended up doing just that. I used a DA sander & stripped the chrome, I purchased the Caswell 2 HSP. buffing kit, used the sewn wheel & black, then sisial with Brown, got into it for about 1.5 to 2 hours & the brand new 2 Hsp. machine died. Caswell did the right thing & stepped up & offerered my money back or the 3/4 machine & the difference back (Thanks Caswell). They are sending me the 3/4 machine asap. I guess there have been problems with the 2 Hsp machine & since they(caswell) stopped selling it. Wish me luck, when the new machine comes in I will finish with loose & white. Bob
sounds great dont forget to post pictures when you finish. nothing like shiny brass
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
| Plating Brass on to Zinc Plated Steel | ksichak | Electroplating Questions | 1 | 09-20-2004 02:38 PM |
| Brass Plating Tank | agugliel75 | Electroplating Questions | 7 | 02-06-2004 08:50 AM |
| Clearcoating brass after polishing | skipmac | Metal Polishing Questions | 1 | 10-04-2003 08:58 AM |
| Brass Weathered Finish Look/Antique Brass | agugliel75 | Metal Polishing Questions | 2 | 06-21-2003 08:09 AM |
| Uh-oh, where'd the brass go? | jtowens | Metal Polishing Questions | 1 | 02-07-2003 02:17 PM |
