  #21 (permalink)
Old 04-20-2005, 04:46 PM
MADMAXX
I'm looking for all show quality
  #22 (permalink)
Old 04-20-2005, 05:53 PM
sswee's Avatar
Moderator
I've been having good results sanding to 600 then starting with spirel/brown. If the part doesn't have many bad places on it, I start at 400 or 600 wet. Then backup on the problem areas and do around them just big enough to feather in to where it don't show a divot when it is shined out.
  #23 (permalink)
Old 04-20-2005, 11:35 PM
MADMAXX
What should I use to maintain after its done?
I've only used mothers so far but I think unbuffed parts are part of the reason for some of the marks.
  #24 (permalink)
Old 04-20-2005, 11:59 PM
sswee's Avatar
Moderator
Mothers or a good carnuba wax. It's an on going process. I anodize most of the parts I do.
  #25 (permalink)
Old 04-21-2005, 12:10 AM
mcaswell's Avatar
Caswell Inc Founder
ZoopSeal is the ultimate protection. http://www.caswellplating.com/buffs/zoopseal.html
Protect all your polished aluminum, stainless steel and chrome parts from oxidation and eliminate the need for repeat polishing. A kit covers 75 square feet. Easy to apply when following the instructions provided. Formulated for use on cars, trucks, boats motorcycles, engines, wheels and interior accessories. When applied properly ZoopSealâ„¢ will:
A hybrid ceramic sealer that protects finishes for up to two years.
Prevent dulling and oxidation
Retain the polished brightness and luster of aluminum
Eliminate the need for repeat polishing
Be long lasting
Will work on aluminum, brass, and stainless steel
Be safe to use and environmentally friendly
Have A Web Site?
  #26 (permalink)
Old 04-21-2005, 09:57 AM
I'm sure Zoop is a good product, but why would I want to have to strip it and possibly re-polish every two years?
  #27 (permalink)
Old 04-21-2005, 03:51 PM
MADMAXX
What happens when you have zoop seal on something and you get something on it, how do you clean it?
  #28 (permalink)
Old 04-21-2005, 09:40 PM
MADMAXX
So I just went thru my strut bar I can give myself a dental exam with it.
I started out at 60grit and took 8 steps to 2000grit all with the 3D sander. Thanks for the help pickleboy. So you was right about the swirl marks, but since I went all the way to 2000grit the compound got them out easy.
When I used the brown compound I could see some of the swirls so I went the oppisite way then after 3 passes they came out. Then I polished it again cleaned it off then went to the white after 6 passes cleaned it off and wheewww cover your eyes.
I'm gonna go crazy with this buffer. By the way think this is to powerful a buffer 8" 1.5 h.p. 3450 rpm 120/240 Volts 7.0/3.5 amps 60 hz? I think it needs a variable speed switch.
THANKS FOR ALL YOUR HELP EVERYONE
  #29 (permalink)
Old 04-21-2005, 10:20 PM
mcaswell's Avatar
Caswell Inc Founder
You'd rather re-polish it every two weeks??
Have A Web Site?
  #30 (permalink)
Old 04-21-2005, 10:22 PM
mcaswell's Avatar
Caswell Inc Founder
From the webpage:
What type of cleaners can be used on Zoopseal?
NO CAUSTIC OR ALKALINE CLEANERS. Only Zoops Cleaner is to be used on the product
Have A Web Site?
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
Need help polishing my polished aluminum wheels suparida Metal Polishing Questions 12 09-02-2005 10:08 AM
Need Help Polishing aluminum Wheels. mattyp Metal Polishing Questions 13 06-14-2004 09:44 PM
Removing blistered chrome from aluminum wheels? ozziepartsguy2003 Electroplating Questions 0 12-14-2003 07:26 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 09:12 AM
