  #31 (permalink)
Old 04-21-2005, 10:52 PM
pickleboy's Avatar
Originally Posted by MADMAXX
By the way think this is to powerful a buffer 8" 1.5 h.p. 3450 rpm 120/240 Volts 7.0/3.5 amps 60 hz? I think it needs a variable speed switch.[/b]
that sound alost exactly like the one i use and it is just fine. i like the ability to exert a lot of pressure and build a good bit of heat. it akes it a lot faster than the 1/3 hp grinder i converted, it would stall out to often and over heat.on mine i a running 8" loose for white and 12" vented for black and brown. its faster than the buff manual says but it works.
  #32 (permalink)
Old 04-23-2005, 11:55 PM
MADMAXX
Originally Posted by caswell
ZoopSeal is the ultimate protection. http://www.caswellplating.com/buffs/zoopseal.html
Protect all your polished aluminum, stainless steel and chrome parts from oxidation and eliminate the need for repeat polishing. A kit covers 75 square feet. Easy to apply when following the instructions provided. Formulated for use on cars, trucks, boats motorcycles, engines, wheels and interior accessories. When applied properly ZoopSealâ„¢ will:
A hybrid ceramic sealer that protects finishes for up to two years.
Prevent dulling and oxidation
Retain the polished brightness and luster of aluminum
Eliminate the need for repeat polishing
Be long lasting
Will work on aluminum, brass, and stainless steel
Be safe to use and environmentally friendly
How does Zoop seal react to heat? Such as polished parts in the engine compartment.
  #33 (permalink)
MADMAXX
Sandblasted valve cover
painted when I get my car back I'm going to polish the **** out of the letters
  #34 (permalink)
Old 04-24-2005, 12:03 AM
MADMAXX
Right side is 2000grit left side polished with buffing wheel
  #35 (permalink)
Old 04-24-2005, 12:06 AM
pickleboy's Avatar
looking good bro keep up the great work.
  #36 (permalink)
Old 04-24-2005, 07:04 PM
MADMAXX
The sandblasted rim I'm going to polish
  #37 (permalink)
Old 04-24-2005, 10:59 PM
mcaswell's Avatar
Caswell Inc Founder
Be long lasting
Can I use Zoopseal on my radiator and will heat affect it?
Yes, you can use Zoopseal on a radiator. Heat from the radiator will help it to cure and make it stronger. We do not recommend putting Zoopseal on an exhaust, this heats up too much.
Have A Web Site?
  #38 (permalink)
Old 04-25-2005, 01:37 PM
Originally Posted by mpierich
I'm sure Zoop is a good product, but why would I want to have to strip it and possibly re-polish every two years?
You'd rather re-polish it every two weeks??
Wipe it down a bit with polish every two weeks, rather than completely strip it every two years? Yes!
  #39 (permalink)
Old 04-30-2005, 11:22 PM
MADMAXX
Heres what the wheels looked like before
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
Need help polishing my polished aluminum wheels suparida Metal Polishing Questions 12 09-02-2005 10:08 AM
Need Help Polishing aluminum Wheels. mattyp Metal Polishing Questions 13 06-14-2004 09:44 PM
Removing blistered chrome from aluminum wheels? ozziepartsguy2003 Electroplating Questions 0 12-14-2003 07:26 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 09:12 AM
