i"m in the process of sandblasting a set of painted aluminum wheels after that i want to polish them and clearcoat if i remeber correct their is a certain type of polish i need to use is this correct? because if i use any type of polish the clearcoat won't adhear to it could someone suggest a good polish thanks
thanks for the reply. i don't think i will have a problem with pitting .because parts of the wheels are already polished from the factory. they are 05 dodge hemi wheels i like the style i think they would just look better polished and i think chrome plating would be to shiny. what do you think?
I think what they are trying to tell you about pits is that cast aluminum has air bubbles in it. When you start to sand, you may uncover some of them, then you have to keep sanding until those are gone and hope to God you don't get into more. Sometimes you find pits, sometimes you don't, that's just the risk you have to take. And be prepared to do a lot of work, the blastprofile from sandblasting can be hard to get out sometimes depending on the hardness of the alum alloy. You would be further ahead to strip the paint off chemically so the underlying surface is smooth to start with. That is of course if the wheels don't have any knicks in it that you would have to sand and polish anyway. Good luck
Too shiney? What's that? I didn't think there was such a thing. LOL You need to go with what you like. I hope your lucky enough not to run into a bunch of pits but don't hold your breath. Unless you have billet rims there is a pretty good chance you'll hit a few. I've machined precision stainless castings, which are suppose to be high quality, and they have pits. Good luck and let us know how it goes. SS
Take it from me and DO NOT SANDBLAST to remove old finish. Use chemical strippers. I sandblasted a set of Cromodora Daytonas for my '81 Fiat Spider and I had the devil of a time sanding them back down and then polishing. I would have been many hours ahead of the game if I simply stripped them.
Now- having said that, I have new problem. The parts of my wheels that I did not polish, but simple remained sandblasted, are now showing pitting and corrosion, despite simply being in my house for the past few months. What could be causing this- and how do I fix or better yet STOP it?? |
Gerarddm,
Hard to say without seeing the parts, but more than likely high humidity combined with contaminates impregnated into the parts by sandblasting. You should be able to stop or at least retard the problem with some WD40 or light weight oil to keep the air out until they can be buffed out. Any kind of corrosion or rust requires oxygen and moisture to occurr. SS |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| Need help polishing my polished aluminum wheels | suparida | Metal Polishing Questions | 12 | 09-02-2005 09:08 AM |
| Need Help Polishing aluminum Wheels. | mattyp | Metal Polishing Questions | 13 | 06-14-2004 08:44 PM |
| Removing blistered chrome from aluminum wheels? | ozziepartsguy2003 | Electroplating Questions | 0 | 12-14-2003 06:26 PM |
| A ? regarding polishing aluminum wheels... | geotexZ71 | Metal Polishing Questions | 4 | 04-25-2003 08:12 AM |
