Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Closed Thread
Old 04-08-2005, 02:54 PM
SoFlaJim
Default Air tool recommendations
Hello,
I have tried a little polishing of various motorcycle parts with a standard drill and a kit I got from Caswell but want to try some die grinders with my spiffy new air compressor.
Looking for some recommendations for what to get, and is the $$ difference between Sears and Harbor Freight worth it?
Thanks,
Jim
Old 04-08-2005, 03:08 PM
easleysp will become famous soon enough
Send a message via AIM to easleysp
We use alot of Central Pnuematic at work. I don't think it's a high end name like Snap-On but they last just as long as any brand we've ever tried, including Snap-On. I'd go with a cheaper one myself after seeing what they go through at work. Someone else might have a different opinion though. Good luck.
Steve
Old 04-08-2005, 07:37 PM
sswee's Avatar
Moderator
Same opinion here. Main thing is to keep them lubricated to prolong tool life. Die grinders just flat wear out with the RPM's they turn. The cheap ones will last about as long as the expensive ones if you take care of them and you can buy 2 or 3 for the same price.
Old 04-10-2005, 09:07 AM
Sears has a "Companion" brand 1/4" die grinder for only $20 - $30. I'm going to stop and get one today. It's only 1/3 horse but it comes in a case with some tools, and has an adapter to use 1/8" tools in it so you can also use Dremel-sized stuff. If I remember I'll post a review of it here.
Old 04-11-2005, 11:10 AM
SoFlaJim
Thanks for the replies.
If the 1/4" grinder is like this one, you might save $10.
LINK VIOLATED TERMS AND CONDITIONS OF USE AND WAS REMOVED
Old 04-12-2005, 01:06 PM
SoFlaJim,
I got the Sears grinder- it's the exact same one. Thanks for the link but I had to get it Sunday and Harbor Freight wasn't open. Another 10 bucks down the drain, lol...
Coulda used it too, 'cause yesterday my compressor motor went out and I had to go get another compressor from Sears. Oh well, that's another couple of valve covers I'l have to polish to pay for the equipment...
BTW, that little grinder works great/
Old 04-13-2005, 12:55 AM
customandsound
Guest
Posts: n/a
why pay 10 bucks for a tool that will not last. spend the extra cash on a good one and it will last you a lot longer..... this is another cas of the product is only as good as the price... been there and when it breaks during a job you are stuck and don't have a spare ...
  #8 (permalink)
Old 04-13-2005, 09:08 AM
I suppose it depends on how much you use a tool. Use it a lot, you need a good one. Use it only a little, why pay 6 times the price? At these prices I could have a couple of spares and still be paying less.
  #9 (permalink)
Old 04-16-2005, 05:37 PM
SoFlaJim
Ok, I got the grinder I was talking about but it's got a 1/4" collet. The adapter I bought for my drill doesn't fit, what should I be using with this grinder? Is it just too small for the 4" wheels?
  #10 (permalink)
Old 04-16-2005, 06:04 PM
I wouldn't use 4" wheels if you got a die grinder (unless you can control the speed). If it's 10,000 rpms +, that's _way_ too fast for a 4" wheels. Your fpm would be about three times recommended speed, plus the wheel is likely to fly apart. See if the max rpms are marked on the wheel.
I use cart rolls or small drum sanders in a grinder. For 4" wheels use a drill or flex shaft at slower rpms.
Closed Thread
Gun recommendations tinbender722 Powder Coating Questions 3 12-17-2004 11:29 PM
Motorcycle frame - what the best tool? NOrrTH Metal Polishing Questions 4 12-14-2004 07:06 AM
What type of air tool for buffing stainless steel? bryaneh Metal Polishing Questions 1 03-03-2003 01:59 PM
Recommendations? Dugan Electroplating Questions 2 01-08-2002 02:35 AM
Recommendations for muffler paint? Hammerman Other Metal Finishing Questions 1 12-17-2001 12:57 PM
