Old 04-14-2005, 08:10 AM
chriscurtis
Default Metal contamination on wheels?
I know you should only use one compound per wheel but what about using the same wheel on different types of metal. For instance, can I use my sisal wheel with emery on stainless then go right to a brass or aluminum piece without hurting anything? Same with the spiral and loose wheels, or do I need a full set of wheels for every type of compound and metal? Thanks for any help.
Old 04-14-2005, 08:47 AM
pickleboy's Avatar
Default Re: Metal contamination on wheels?
i dont use a different wheel for different metal. but i do rake real good when switching metals and reload with compound. this should be enough, if not and you get scrathing on the softer metals then get more wheels they are cheap after all. but try raking first. if done right the wheel will be cleaned out of most all residue of the last metal.
PLATING POT METAL............... 48Buick Plating Pot Metal 31 08-29-2007 11:40 AM
Plating over cold metal casting jh2ohouse Electroplating Questions 2 12-16-2006 08:28 PM
Refinishing Metal Golf Club Heads BillSchultz Other Metal Finishing Questions 0 08-17-2003 10:40 AM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 08:12 AM
Pot Metal Plating questions Dave Electroplating Questions 1 04-03-2002 05:37 PM
