Old 04-15-2005, 08:35 AM
berndog will become famous soon enough
Send a message via MSN to berndog Send a message via Yahoo to berndog
Default harley parts
I've been polishing a lot of harley parts lately,,any sugestions from anyone,re:what is the best wheel or bob setup to use for the valleys,&nooks and cranny's
Old 04-15-2005, 09:54 AM
pickleboy's Avatar
Default Re: harley parts
i have been using my 1/2" air drill w/ felt bobs and dremel with pretty good sucess. i have not got a chrome like finish yet but when i bought the harley it was mistreated badly and the alum covers were oxided pretty bad. the caswell bob set is a good selection and should work for you with regular compound or greaseless. i suggest a 1/2" drill due to higher torque. it wont bog down as easy. best of luck
Old 04-15-2005, 12:37 PM
I use the cartridge rolls 80/120/240/320, then cotton Dremel wheels and felt bobs. Emery compound is usually enough for the tight areas but the large areas you should go to white rouge.
Old 04-15-2005, 12:46 PM
pickleboy's Avatar
i fully agree but i have not as yet used cartridge rolls i have instead used cratex rubber abrasives. as for compound i go to white even on small wheels for the dremel. my question is do the cartridge rolls come in a pointed version or only the straight cylinder shape i have seen? if so i think they will last longer than cratex. hopefully caswell will start to sell both of these soon as i am tired of looking all over for them.
Old 04-15-2005, 03:44 PM
Yes, the cart rolls come in pointed and flat. I have a tiny drum sander with replaceable sleeves so I use that for easy flat areas. The tapered ones are dynamite, but be careful when the point wears down to where the shaft sticks out.
Send me a private message and I'll tell you where to get the tapered ones if you don't know already. Don't want to p*ss off Caswell - but why they make me buy them elsewhere and pay extra shipping is a mystery.
Old 04-16-2005, 12:25 AM
does anyone use the heavy dudty flex shaft that attaches to your stationary polisher?
Old 04-16-2005, 11:05 AM
pickleboy's Avatar
hey berndog this guy has one. customandsound he was a moderator here.
he has moved on from polishing but has a ton of experience and a good knowledge of different tools. here is his website also www.customandsound.com
  #8 (permalink)
Old 04-16-2005, 05:08 PM
I was using cheap Harbor Freight shafts - don't do that, they don't last long. I put a drill chuck on a 1350 rpm motor and chucked the shaft into that - worked great as long as it lasted. I am definitely going to get the good one soon. But this time I will make guides for it on my bench to keep it from twisting up on itself when I use pressure.
Copy Chrome on engine parts and plastic, alot of can I's cgworth Copy Chrome Kit Customers Only 3 08-29-2005 12:38 PM
Help cleaning just polished parts bonesaz Metal Polishing Questions 3 10-12-2004 06:58 PM
Best Way to strip Chrome Live2Ride_88 Metal Polishing Questions 9 03-16-2004 03:25 PM
trouble with black, anyone got any ideas? wvdon Anodizing Questions 1 03-11-2004 02:37 PM
Curing multiple parts of varying size in oven at same time?? Fireblade Powder Coating Questions 3 09-28-2003 08:10 AM
