Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Closed Thread
Old 05-26-2005, 04:30 PM
mpgcustoms
Default Polishing a motorcycle engine
I have a new motorcycle engine I want to polish to a chrome "like" finish. What is the best compounds and devices to use? What would be the best full kit to do this work?
Old 05-27-2005, 09:38 AM
Default Re: Polishing a motorcycle engine
First, look at Caswell's polishing manual - you can download it in PDF format, then you'll have a better idea of what questions to ask.
What engine is it? Is it a rough-cast finish or already smooth?
Old 06-11-2005, 01:58 AM
customandsound
Guest
Posts: n/a
the more time you take prepping the better the out come will be .. good luck
Closed Thread
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 62 05-18-2009 02:23 PM
Polishing cast aluminum motorcycle engine cases. Mutt Metal Polishing Questions 1 07-17-2005 12:46 AM
anodizing a motorcycle engine dtiensvold2 Anodizing Questions 3 04-11-2004 10:25 PM
Motorcycle Engine polishing tomlando Metal Polishing Questions 6 01-17-2004 04:28 PM
Polishing Aluminum (Engine intake) RyanT Metal Polishing Questions 3 02-25-2003 08:53 PM
