  #21 (permalink)
Old 06-28-2005, 12:41 PM
pickleboy's Avatar
yeah mike been real busy w/ s.s. trim. i hate s.s. its such a pain, i am ordering some special bars from caswell this week to try(fastcut s.s. bar) hopefully that will make a difference. also been working on getting the scooter back together, i cant wait to ride again. also about to start up the powder coating game. i think i can make more $$ faster that way. how about you bro life treating you good? keep in touch.
cliff
  #22 (permalink)
Old 06-29-2005, 08:04 AM
pickle,
Things are slow now but I'm glad...I have a day job, and was polishing til 9 pm most nights all spring. Just finished an intake manifold, ended up making half the minimum wage but oh the experience, lol. Only stainless I've done was a brake rotor for a shovelhead. I found out you don't start too coarse 'cause it's a bitch to get the scratches out.
Dunno zackly where you're located but hey half the riding season's gone where I live...better get it on and get in the wnd, man!
I looked at powdercoating but decided to stick with the polishing - it's got the lowest overhead for me. Might get into smalltime plating after a while...platers around here only do industrial stuff.
Later...
  #23 (permalink)
Old 06-29-2005, 04:11 PM
turbohardtop
well, I went ahead and bought the caswell 3/4hp, 3600rpm kit. I hope this unit would run more than 10 minutes before it lose it power. the converted grinder I had would get so weak when it heats up after 5 minutes of use. It was useless for any polishing.
  #24 (permalink)
Old 07-01-2005, 03:26 AM
customandsound
Guest
Posts: n/a
did you order a buffer ? or just convert a old motor
  #25 (permalink)
Old 07-01-2005, 10:09 AM
turbohardtop
I was using a converted grinder but it was heating up so fast so I decided to order a new 3/4 motor from Caswell. I hope this is sufficient for my polishing jobs.
  #26 (permalink)
Old 07-03-2005, 08:58 AM
customandsound
Guest
Posts: n/a
it will work .. i got a 3/4hp dual speed buffer and i got to old motors that are 3/4 1 being higher then the other on rpms i use them for polishing tail lights and composted head lights .. but for metal polishing the 3/4 will work good unless you want to go bigger on hp and trust me the part will get hotter quicker
  #27 (permalink)
Old 07-05-2005, 10:10 AM
turbohardtop
oh, I meant the motor that I was using got heated up so fast and it became so weak that I could put any pressure on the grinder/buffer.
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Polishing cast aluminum motorcycle engine cases. Mutt Metal Polishing Questions 1 07-16-2005 11:46 PM
ok! cast aluminum polishing Carcher7878 Powder Coating Questions 4 05-20-2004 09:53 PM
Cast Aluminum polishing? Neons4life Metal Polishing Questions 4 02-01-2004 02:45 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 08:12 AM
